12th Feb 2011, 9:04 pm | #1 |
Which BF245 FET to use?
The reflex receiver circuit, link below, originally used a HEPF0015 FET which cross references to the BF245:
http://www.crystalradio.net/transist...ges/snare2.jpg Now, BF245 FETs come in A, B and C versions and so I am wondering which version would be the best suited for this circuit? Norman Bourassa |
12th Feb 2011, 9:40 pm | #2 |
Re: Which BF245 FET to use?
It probably won't make a lot, if any, difference in that sort of circuit. Here is a data sheet that covers all three versions. You can compare it with the data sheet of the original type.
http://www.fairchildsemi.com/ds/BF/BF245C.pdf SB
12th Feb 2011, 9:54 pm | #3 |
The differing charcteristics are listed in the datasheet here.
http://pdf1.alldatasheet.com/datashe...ENS/BF245.html Hope that helps a bit. I wouldn't have thought that in such a simple circuit there'd be any discernable difference whichever version BF245 you used, but that's just my view. Best of luck with the project. David |
12th Feb 2011, 9:59 pm | #4 |
It really should make little difference as the lads have said.
12th Feb 2011, 10:00 pm | #5 |
Hello,
The drain current is diffrent when Vgs = 0.(see attachement). I think the difference will hardly be noticed in your circuit. Greetings, Bertus |
