23rd Apr 2010, 4:35 pm | #1 |
Build of a Micropower AM 'Pantry' Transmitter
This is a little project which, on and off, occupied me for most of 2009. I wanted to use my AM radios more, for Radio 2 and Classic FM, which of course are not available on LW or MW. So I designed and developed a micropower 'pantry' transmitter. I designed with the following aims in mind:
* Good audio frequency response * Low distortion up to high percentage modulation levels * Good frequency stability * Minimal radiated harmonics * Long life, high reliability * Vintage technology * Auxiliary power output, to operate low-voltage signal source (FM radio, CD player, etc) I really wanted to use valves, and shall do in a future version. But for now I succumbed to a transistorised circuit. For vintageness, germanium is obviously preferred, but I don't have any with reasonable voltage and current ratings which work above audio frequencies. So I settled for silicon. Keeping technology as vintage as possible, there are no IC's in the signal path, although I did cheat by using three IC voltage regulators. Early experiments showed a modulated oscillator is not the way forward. So, I have a master oscillator, buffer, and (micro) power stage operating in Class E (resonant switching) which is where modulation stakes place. AF input sensitivity is sufficient for full modulation from 100mV or so, all AF amplification being Class A. I considered operation in the LW band but I could see a few complexities arising because the carrier frequency is little more than a decade above the highest audio frequency; SW would have been nice, but here I was worried about radiation being too effective and being detectable down the road. So I opted for MW. I included an 'overmodulation' LED which operates at about 95% modulation, to ease the setting up and adjustment of input level. This works particularly well, giving a well-defined indication even on brief transient peaks of speech or music. Although distortion is pretty low, I added negative feedback (about 6db) at AF, mainly to straighten out the frequency response. Otherwise, sideband cutting in the RF tank circuits clobbers the treble (though it is still better than 'official' broadcasts). The circuit is built on a piece of 0.1" plain matrix board, and housed in an Indian wooden carved box, which suits the job admirably. It is powered from the mains via a plug-top type power supply. It has been running almost continuously for several months now, with no failures, driving a few feet of aerial wire, and is one of the most useful projects I have ever made! |
23rd Apr 2010, 4:50 pm | #2 |
Re: Build of a Micropower AM 'Pantry' Transmitter
Hi Kalee20,
What a good looking bit of kit. Did you think about an internal battery to keep the unit even more compact or was this not possible? Regards Rob |
23rd Apr 2010, 5:00 pm | #3 |
Hi Rob,
I wanted something running all my waking hours (actually it's been running 24/7), and mains operation was dictated by this. Batteries were never a consideration! |
23rd Apr 2010, 5:13 pm | #4 |
That trace is really clean. Ps what's that on top of the box?
Dave |
23rd Apr 2010, 5:14 pm | #5 |
Looks like a good design though I admit I know little about transmitter design. In particular you haven't sought to keep down the parts count. Transistors and passives cost very little so there's no need to prune the design unless it's intended for mass production.
I wonder if there's an easy route to providing a synthsised RF oscillator so the output frequency can be simply selected in 9kHz steps. ISTR a MW TX by Dinosaur, the same guys that did an earlier successful 625>405 converter. Date possibly late 1980s, early 90s, certainly not available now. I have no idea what methods they used but I suspect that results would have been very good. |
23rd Apr 2010, 5:49 pm | #6 | |
Just an inlaid brass embellishment, part of the box. Unusual in a transmitter, sets it apart from others, don't you think?
Probably, and I have a few ideas. However, using a frequency counter (with input waving in the air near my transmitting aerial), I've seen a variation of less than 80Hz over a month (taking readings at various times of the day to encompass temperature changes. Not up to broadcast stability, but good enough! |
23rd Apr 2010, 6:53 pm | #7 |
Hi peter,
Any chance of a peek at the circuit, always interested... Dom |
23rd Apr 2010, 7:02 pm | #8 |
Dom, see 'Attached Files' in post #1
23rd Apr 2010, 7:29 pm | #9 | |
Very nice job.
Presumably all the BC547s could be replaced with any general purpose Si NPN transistor? Paul |
23rd Apr 2010, 8:58 pm | #10 |
I'm pleased to see you used a Class E PA. It modulates nicely and generates less harmonics than Class C, although high efficiency is not an issue here!
24th Apr 2010, 10:53 am | #11 | |
I standardised on TO92-encapsulated devices, makes for a circuit board more pleasing to the eye, that's all! The voltage stabilisation to the oscillator is to help frequency stability (one of my design aims). The 15V main stabilised line is just so that I had a known voltage to run from - if I was adding a mains transformer plus rectifier I'd probably dump this, although at the cost of one capacitor and one IC it won't reduce the parts count by much! The auxiliary power output is only there for when I use a cheap portable CD player as signal source, of course, and make it independent of batteries without using multiple mains adaptors. The parts count could be reduced more - C1 could go, so could R29. And the demodulator/negative feedback could all go (I ran for 5 months without it - but it does improve frequency response). Detailed write-up will appear later this evening for anyone interested (Dom perhaps?). But it runs to a couple of A4 sides so it'll be as a pdf attachment! |
24th Apr 2010, 11:44 am | #12 |
Very nice.
I'd certainly be interested in a write up. I've been developing ideas along similar lines for a while now - you've got further than I have!
Brian |
24th Apr 2010, 4:37 pm | #13 | |
Here is a photo of the set-up all set up. This uses a (modified) REPLICA Bush DAC90a FM radio as signal source, powered from my auxiliary DC outlet (normally I keep them a few feet apart, hence the coiled-up cable. Maybe this isn't so much a 'pantry' transmitter as a 'sideboard' transmitter...
See pdf file below, Brian. And do progress with yours! |
24th Apr 2010, 6:11 pm | #14 |
Nice piece of work, Peter. I love the vintage trimmer caps.... you just could no resist could you.
The 100 Hz drift that you are getting, I know it is adequate but since you aimed to get the minimum of drift from the beginning , do you think you have achieved that or could it be bettered. Mike |
24th Apr 2010, 7:46 pm | #15 |
Beautiful, great job. Nice write-up. It's on the project list.
Jim Mac |
24th Apr 2010, 9:07 pm | #16 |
Hi Peter.
Perhaps you should do a production run of PCB's I certainly would buy two off you. Cracking work!
25th Apr 2010, 8:49 pm | #17 | |||
Both of these might help with stability, in that moisture absorption due to changing humidity levels can cause frequency to vary. An impregnated coil won't absorb moisture; and whether flux residues are hygroscopic or not I don't know. But hi-rel applications always require flux removal. Down side is it will take a few weeks before I can assess whether there's been any improvement! If I wanted any serious improvement now, I would stick the thing in an oven and plot frequency against temperature, and use this to decide whether I can compensate for temperature changes by a suitable TC capacitor. However, for the mo, it's satisfactory! |
26th Apr 2010, 11:04 am | #18 |
Could i ask where most of the bits came from?
Thank You David |
26th Apr 2010, 1:54 pm | #19 |
Thanks for the write up and the circuit (and sorry I didn't spot it been a bit distracted with family matters this week).
A very interesting circuit and as ever an excellent description of how it works! I'm going to have to (try to) analyse how you got your NFB working! I never got mine to work that well, demodulating the signal. When I tried as I was struggling to get stability with all the various poles needed to remove the RF from the AF etc... Thanks! Dom |
26th Apr 2010, 2:11 pm | #20 | |
This looks a very nice design. Most of the components look straight forward to source with the possible exception the coils; where could I get them or will I have to wind them myself? Regards Colin |
