23rd Feb 2021, 11:11 pm | #1 |
B9A valve base footprint?
Hi!
Has any Member made a B9A valve base footprint to use in Design Spark, Sprint Layout, Altium etc., etc., and can tell me suitable pad sizes please? Am I correct in using 36 degrees for the angle between adjacent pins with pin 5 in the vertical plane? I am using a "stand–off" type valveholder on the design so there's a tolerance, ±1 mm or so on the p.c.d. Chris Williams
It's an enigma, that's what it is! This thing's not fixed because it doesn't want to be fixed! Last edited by Chris55000; 23rd Feb 2021 at 11:19 pm. |
24th Feb 2021, 12:25 pm | #2 |
Re: B9A valve base footprint?
I take it that you are talking about a PCB mounted base? If so it depends on the particular base you are thinking of using.
FWIW the B9A footprint in KiCAD is pins on a PCD of 11.76mm, pad diameter 2mm and a 1mm hole. Craig |
24th Feb 2021, 12:29 pm | #3 |
Tried to upload the KiCad model, but the upload manager can't cope with a .mod file extension!
Craig |
24th Feb 2021, 12:40 pm | #4 |
24th Feb 2021, 2:00 pm | #5 |
Looks a bit like the old confusion between "valve base" and "valve holder". By valve base I think one generally means the base that is part of the valve. Valve holder being the holder that sits in the chassis or on the PCB or whatever.
Graham
Half my stuff is junk - trouble is, I don't know which half! |
24th Feb 2021, 3:06 pm | #6 |
Hi.
I did one in Sprint to suit Belton PCB sockets as follows: 21mm PCD Pads 4mm dia with 1.2mm holes. 36 degrees indexing. Hope that helps!
Howard G7AJN/M3OCL "How hard can it be?" - Jeremy Clarkson |
24th Feb 2021, 3:58 pm | #7 |
Afternoon Howard!
Me thinks that should meet my needs nicely – Cheers Howard! Chris Williams
