Old 27th Jul 2019, 6:48 pm   #1
davebms
Default Graves S-3
hello all, I have found some pics of a Graves S-3 on the forum (dated 2012). I have a chassis from a member here, it has later valves HLS 2off and LP2
before the photos fade away and the circuit diagram get lost I will try to put it together, any information welcome !
dave
Name:	graves 3 002.jpg
ID:	187438   Click image for larger version
ID:	187439   Click image for larger version
davebms is offline
Old 27th Jul 2019, 10:53 pm   #2
Default Re: graves s-3
HLS? Is that a typo for HL2?
Can't find an HLS listed anywhere.....
Herald1360 is online now
Old 27th Jul 2019, 11:00 pm   #3
Lloyd 1985
Lloyd 1985's Avatar
Interesting, I have a Graves set with a similar looking chassis, my cabinet is totally different though, and I’ve never found any service data for it! I’ll try and find a picture of it..
Lloyd
Edit; found a pic! Sorry it’s fuzzy, it’s cut out of a bigger shot.
Lloyd 1985 is offline
Old 27th Jul 2019, 11:32 pm   #4
davebms
YES typo, got to exited with manage attachments first attempt !! ,, but doubt that you had to look it up !
davebms is offline
Old 1st Aug 2019, 4:18 pm   #5
davebms
hello all, thanks for the reply's same as you Lloyd, I can find no information on this chassis, but I have a circuit diagram made by the
previous owner and a map of the under chassis I think I can work it
out.. the valves and interstage transformer are good ,,the coil pack
had a wire off but all good now The lemco .001mf 1500volt are not good and one has Brocken lead out, the only 1nf caps I have are RS172-7766 I think these are suppression
types can I use them ?
thanks dave
ID:	187703   Click image for larger version
davebms is offline
Old 1st Aug 2019, 4:20 pm   #6
HamishBoxer
HamishBoxer's Avatar
Default Re: Graves S-3
Should be fine.
HamishBoxer is offline
Old 1st Aug 2019, 6:08 pm   #7
davebms
thank you, I will paint them black, electric blue is a bit ott !
dave
davebms is offline
Old 14th Aug 2019, 8:10 pm   #8
davebms
hello all I have re assembled most of this chassis, I have been looking
at this and other 3 valve circuits all looks ok , there are 2 chokes in this
chassis one is in the anode feed 40mh /140r with a resistor the other is wired via
a switch, to the coil pack I was hopping to repair it ,but is to damaged
its go at least 6 loose ends
wire single strand cloth covered
wire .005" 1/4" wide 1" od wave wound
any educated guesses as to what to replace it with
thanks dave
ID:	188340   Click image for larger version
davebms is offline
Old 14th Aug 2019, 10:09 pm   #9
PJL
Can you post a picture of the circuit diagram you have identifying where the coil is connected and the function of the switch. We need to know if it forms part of the tuned circuit.
PJL is offline
Old 15th Aug 2019, 10:48 am   #10
davebms
thanks for the reply's. will attach photos of what I have, can try to
take pics of switch later if required
dave
Name:	graves s3 005.jpg
ID:	188355   Click image for larger version
Name:	graves s3 006.jpg
davebms is offline
Old 15th Aug 2019, 2:07 pm   #11
PJL
The original offer shows a few extra pictures https://www.vintage-radio.net/forum/...d.php?t=153064 including the switch.
It appears the RF coil is only in circuit on LW and connects Coil pin 5 to the aerial. We will need the coil arrangement before we can say what it does but MW should work without it.
PJL is offline
Old 16th Aug 2019, 8:19 pm   #12
davebms
the best I can do re coil arrangement is post some pics , the top part
of the coil pack looks similar to a Repanco DRR2 . if so. then pin5 goes to
the long wave (I think). reading, f j camm ,chokes are used in the LW to
prevent MW breaking through possibly that was what it was ?
thanks for the help, dave
Name:	graves s3 coils 002.jpg
ID:	188443   Click image for larger version
Name:	graves s3 coils 003.jpg
ID:	188444   Click image for larger version
Name:	graves s3 coils 004.jpg
ID:	188445   Click image for larger version
Name:	graves s3 coils 006.jpg
ID:	188446   Click image for larger version
Name:	graves s3 coils 007.jpg
davebms is offline
Old 16th Aug 2019, 8:47 pm   #13
PJL
I think we go with F J Camm then as it would take me a while to get my head around those coils. I would patch up what you have as best as you can by joining up the broken bits and wire it back in as it will be non-critical. You could spend many hours trying to wave wind by hand but it might not work much better.
PJL is offline
Old 16th Aug 2019, 9:07 pm   #14
davebms
thank you (,yes a lot seems to go on in the coil pack) my thoughts are to continue with the build, snip the wire where it exits the top of the chassis. try to get going on MW. and experiment with long wave (I have some chokes from norman reaburn,, so will see how it goes
thank all dave
davebms is offline
Old 29th Aug 2019, 9:11 pm   #15
davebms
Hello all, I patched the choke, as best I can, found all the ends, joined
them ,insulated with nail varnish .had to make cheeks to hold it in position. was 1.62mh went up 1.8mh when pushed together and coated with shellac .. well it looks ok I have a RS transformer that should work to get to a small 8ohm speaker, will try to get a long wire up at the week end.
Power supply GB-4.5v no problem. 2volt lead acid ok ,, I have a 90 volt at 30ma battery eliminator will that work for HT
thanks dave
davebms is offline
