Old 15th Aug 2019, 8:11 pm   #1
poppydog
Default Telefunken Gavotte 8 Export. Freebie.
I recently acquired this radio and a search on this site for any threads or service info on it turned up nothing so I thought I would post on here as I thought it might be of some interest.
I was given this yesterday (for free) by a nice old boy who I do a bit of work for now and again, it had been in his loft for around 40 years till a couple of days ago. It appears to be complete apart from a bright missing on the on/off switch. I’m not really into valve radios due to the high voltages and the crammed in components but I was taken by its compact size, good looks, 3 speakers and a good selection of wavebands. I haven’t powered it up but the chap assured me it worked well before they moved to their current location deep in a mining valley near me. Being so low in a valley the radio wouldn’t pick anything up so was redundant and ended up in the loft.
I plan to have a go at this after Christmas but in the mean time I will try to source as much service info etc. as I possibly can, so will put a request for some service info other than a schematic in the wanted section. Some pics below..
Poppydog
ID:	188383   Click image for larger version
ID:	188384   Click image for larger version
ID:	188385   Click image for larger version
ID:	188386   Click image for larger version
poppydog is offline
Old 15th Aug 2019, 11:38 pm   #2
simpsons
Default Re: Telefunken Gavotte 8 Export freebie
Google "Govette 8U radio schematic" and you will find what you need in images and then just Google "Telefunken Govette" for Phil's Old Radios take on the similar model 9 .
Chris
Last edited by simpsons; 15th Aug 2019 at 11:59 pm. Reason: Additional information
simpsons is offline
Old 16th Aug 2019, 11:48 am   #3
GeoffK
A nice well build radio, it is fairly conventional. Similar to the Grundig 2066. It has an ECC85 double triode VHF FM tuner between 87.5 to 100MHz so not getting to the top end of 108MHz.
It has a full wave solid state bridge rectifier instead of a valve rectifier, a B250 C75 N2, this a selenium type.
Valve line up ECC85, ECH81, EF89, EABC80,EL84 and EM80 tuning indicator. Should be straight forward to work on.
Geoff
GeoffK is offline
Old 16th Aug 2019, 6:51 pm   #4
GeoffK
A silicon bridge rectifier 2 Amp 240V and a 100 Ohm 5 Watt resistor in series can replace the selinium bridge rectifier for better reliability.
Geoff
GeoffK is offline
Old 16th Aug 2019, 7:18 pm   #5
poppydog
Thanks for the help on the info Chris, I was typing in my specific model on Google and not getting much at all however your suggestion has helped find the help/info I am going to need.
Bit disappointing that it only goes up to 100MHz Geoff, but I think I can live with that, I can still pick up radio 1 though I am actually looking forward to having a go at this.
Reading up on these radios it seems they are excellent performers and quite soughtafter, so I am a little disappointed that there is so little interest in this, perhaps I should have said I wanted to Bluetooth it or play my guitar through it..
Regards Poppydog
poppydog is offline
Old 16th Aug 2019, 7:32 pm   #6
Link for the Telefunken Gavotte 8 Export schematic:
https://www.doctsf.com/documents/aff...1209&num_fic=1
Old 18th Aug 2019, 3:11 pm   #7
poppydog
Default Re: Telefunken Gavotte 8 Export. Freebie.
Thanks Lawrence, I now have accumulated all the info I need.
Regards Poppydog
poppydog is offline
Old 20th Aug 2019, 8:44 am   #8
rojosuiza
rojosuiza's Avatar
it is an excellent radio.
Wait, till you see its shortwave fine-tune in operation!
Do never say things like 'bluetooth it', 'play my guitar through it', because they hurt a radio's feelings...
rojosuiza is offline
Old 20th Aug 2019, 8:57 am   #9
rojosuiza
rojosuiza's Avatar
Look at the radio mountain to the right of the radio tower - you see another wonderful Gavotte...
Old 20th Aug 2019, 7:56 pm   #10
poppydog
No I wouldn't do that to any of my stuff, unfortunately it seems to get pulses racing on here
I saw a video on youtube late 1 night showing that sw fine tuning in operation, very clever.
Regards poppydog
poppydog is offline
