27th Dec 2022, 8:09 pm | #1 |
AC or DC TX
Can a mains Transformer run on DC supply?
John.
My favourite text message "I'll be there in five minutes, if not read again" |
27th Dec 2022, 8:12 pm | #2 |
Re: AC or DC TX
No. The voltages are induced in the secondary windings by a changing magnetic field in the core. By definition DC doesn't change, so it can't induce a changing field.
Cheers, GJ
http://www.ampregen.com |
27th Dec 2022, 8:12 pm | #3 |
Re: AC or DC TX
no! is the simple answer
I don't suffer from Insanity. I enjoy every minute of it. |
27th Dec 2022, 8:24 pm | #4 |
Re: AC or DC TX
Exactly what I thought. Bush AC34 circuit.
John.
27th Dec 2022, 8:39 pm | #5 |
Re: AC or DC TX
Yes, it's a contradiction in terms. Transformers only work with AC. If you put DC into a transformer primary, you just get an electric heater. Somebody in the Olden Days has made a draughting error.
27th Dec 2022, 9:02 pm | #6 |
Re: AC or DC TX
I gather that several Bush models (and ISTR some other makers) used series-string valves in both AC/DC and AC-only sets, presumably to simplify production, with AC-only models feeding the heater string from an appropriate-voltage tapping on the HT secondary. Possibly, the draftsman substituted the transformer symbol for the dropper symbol in the circuit diagram without also altering the wording?
27th Dec 2022, 9:07 pm | #7 |
Re: AC or DC TX
An unusual howler from the offices of the W&ET there.
27th Dec 2022, 10:16 pm | #8 |
Re: AC or DC TX
I suspected a printing error. Then I did wonder if the wiring was intended be connected to the primary side and used as an auto TX on DC, but I don't think this was suggested. I don't know if an auto TX would work on DC.
John.
27th Dec 2022, 10:18 pm | #9 |
Re: AC or DC TX
Yes this has been noted before. I noticed it when restoring my own AC34 and suspect Turretslug is correct in his assumption. Bush used several chassis with series string valve heaters but using a transformer. It simply meant they could use exactly the same chassis and just substitute a dropper for the transformer in the case of DC mains. It's a shame that Trader didn't notice the error before going to press.
27th Dec 2022, 10:20 pm | #10 |
Re: AC or DC TX
I suspect the circuits for the DAC34 and AC34 were drawn up at the same time.
One of the things that should not have been copied across! Cheers Mike T
27th Dec 2022, 10:26 pm | #11 |
Re: AC or DC TX
Surely the comments above equally apply to an auto-transformer. The best it could achieve is to act as a (not very good) dropper.
27th Dec 2022, 10:26 pm | #12 |
Re: AC or DC TX
Could be quite frisky if anyone tries wiring one that way. Drafting or translation of technical things by non-technical people, who don't understand what they're describing is always risky.
Autotransformers don't do DC either, of course. David
27th Dec 2022, 10:33 pm | #13 |
Re: AC or DC TX
Thank you everyone, point taken. When I first saw the circuit I did not know if it was a mistake or some ingenious circuit, I now know.
This might as well be closed. John.
27th Dec 2022, 10:34 pm | #14 |
Re: AC or DC TX
Lots of early 50s Ekco sets also used series string heaters and a mains transformer. It may have simplified the parts inventory, and perhaps U-series valves were priced lower than E-series.
