12th Nov 2022, 10:45 pm | #1 |
Using 100V line transformers as p-p o/p transformers
Post moved from this thread:
https://www.vintage-radio.net/forum/...d.php?t=195920 How do you use a 100v line transformer as a push-pull? Last edited by Cobaltblue; 13th Nov 2022 at 1:37 pm. Reason: New thread created |
13th Nov 2022, 9:08 am | #2 |
Re: 100v line transformers
To take the 15W as an example
Connect as follows Anode 1 - Com Screen 1 - 15W HT (centre) - 5W Screen 2 - 2.5W Anode 2 - 1.25W See the attached spread sheet for the calcs. The 15W is the only one that gives precisely matching screen taps but I have tested the 30W version and despite the slight mismatch I could not measure any detrimental effects. My main amplifier used in the house is a Mullard 5-10 using the 30W ones. Peter |
13th Nov 2022, 9:24 am | #3 |
I forgot to add that the Silicon chip (and Everyday Practical Electronics) Currawong valve amplifier used 100V line transformers
https://www.radiomuseum.org/r/silico...ifier_kit.html Peter |
13th Nov 2022, 3:22 pm | #4 |
I have used the same approach in a transmitter modulator, like the Codar AT5 but with an 807 PA and 6L6 as modulator in Class AB1. The anode currents balance out more or less so that you can use quite a small transformer and still get 100% modulation without the core saturation being an issue.
13th Nov 2022, 5:15 pm | #5 |
Re: Using 100V line transformers as p-p o/p transformers
How does that work then? I just looked at a very small ctt diag. for and AT5, and it looks like a centre tapped transformer with one side feeding the anode of the mod valve and the other feeding the RF PA anode via the usual RFC, The HT goes to the centre tap it seems. Would I be correct in assuming that the currents are 180 degrees out of phase and cancel (well partially in reality) and not add?
"Behind every crowd, there's a silver Moonshine" |
13th Nov 2022, 5:22 pm | #6 |
Yes, essentially it is a kind of 1:1 autotransformer with equal and opposite current flowing in the two halves so that the magnetic fields sum to zero under static conditions. Applying audio drive to the modulator unbalances the field contribution from the modulator, which results in the audio output being applied to the PA stage. The only downside is that you have to use the same HT on both the PA and modulator valves, but since an 807 is really a 6L6 with a top cap they are reasonably well matched.
14th Nov 2022, 11:34 am | #7 |
The forum members at australian guitar gear forum (https://www.aggh.net/discussion/index.php?board=8.0) have made use of 100V line Tx's in guitar amps, I haven't tried one my self but by all accounts they work well.
14th Nov 2022, 3:35 pm | #8 |
Remember that they're only designed for 100Vac across the primary, above which they're likely to saturate (at 50Hz? 100Hz? Who knows). At typical valve primary impedances that means you'll never get more than 2-3 watts out at the low audio end, before saturation.
