7th Jan 2019, 12:27 pm | #1 |
Dubilier/RS white axial caps - which dielectric?
Hi All,
I have some 0.015uF 400V white caps here, some marked Dubilier, some marked RS. Does anyone have knowledge or an old RS catalogue which gives details of the actual dielectric type used in these caps? I have encountered there were several colour versions of these caps: white, grey, two tone blue, white/blue.. so I just want to know what dielectric was, it would be useful to know what the other colours' dielectric was too ... I've attached a photo of the cap in question Thanks for any help chaps!
...where on earth did that spring/screw go?? |
7th Jan 2019, 12:32 pm | #2 |
Re: Dubilier/RS white axial caps - which dielectric?
They are mixed dielectric, paper and some type of plastic. I would not use them, they were better than paper only types but still failed, especially in pulse circuits.
Frank |
7th Jan 2019, 12:40 pm | #3 |
Thanks for that info Frank!
Were they grey ones any better?
7th Jan 2019, 12:41 pm | #4 |
7th Jan 2019, 2:02 pm | #5 |
Thanks again chaps, now that you mention the term 'mixed dielectric' it has jogged my memory - thanks for the details which further expand my knowledge!
7th Jan 2019, 2:27 pm | #6 |
7th Jan 2019, 3:27 pm | #7 |
I recently bought an old valve amplifier which included some of the two-tone version of these caps. I thought that they looked quite promising with their smart intact encapsulation, but leakage measurements suggest that they use a dielectric of damp paper. Some of mine measured around 10Kohms!
Martin
BVWS Member |
7th Jan 2019, 3:28 pm | #8 |
I've got a few, half blue / half grey moulding. Came from Electrovalue in the 1970's, catalogued as 'mixed dielectric.'
I have come to understand that they are paper/plastic. But anything paper in a capacitor is to me now, a recipe for leakage at some point in the future - in short, a no-no! |
7th Jan 2019, 3:49 pm | #9 |
Maybe these jobbies?
7th Jan 2019, 4:44 pm | #10 |
7th Jan 2019, 5:18 pm | #11 |
Hi
These mixed dielectric capacitors were often used in mains filter circuits and as the boost capacitor in valve line output stages. They weren't all that good back in the day but mustn't complain as they used to keep us a busy with simple repairs. I have quite a few in my collection but wouldn't use them. A fair number exhibit swelling and cracking probably due to the paper being hygroscopic. From memory, the blue/yellow ones as in David's post, were used in BRC TVs such as the 1400 chassis. I never did find out if the colours of the case were of any significance. Regards Symon |
7th Jan 2019, 11:06 pm | #12 |
I think the usual problem with these was that the plastic case was moulded in two halves and would crack at the seam and allow moisture ingress. It's very common to see this, even in unused old stock examples.
I am guessing that the plastic was affected by temperature cycling. A bit like the problem with the dreaded Hunts types. |
8th Jan 2019, 5:35 am | #13 |
I have bins full of the white ones, all new, look perfect, in various values and voltages.
I was hoping to sell them to the audiophools on ebay and buy a mansion, a Ferrari and another boat. Please don't tell anyone else that they are useless, keep it between you and me. |
9th Jan 2019, 8:05 am | #14 |
Interesting, I too too have a few of these types but mine are dark blue/light blue. I have some big ones rated at 1kv, usually use this sort of thing when fault finding on scopes say to temp replace components to get a circuit working.
Not all paper caps are KO'd, I have some Dubilier 1u 600v, these are rather useful, it ain't easy to find similar rated caps. Out of a jar of about 20, 2 were leaky. Andy.
9th Jan 2019, 4:14 pm | #15 |
One of those Dubilier yellow & blue jobbies in a Ferguson CTV with the Thorm 8500 series chassis gave me the biggest fright of my life, ever. The shock as it exploded literally made be jump. Both of my feet left the ground. It went off six inches from my right ear hole.
Split the case wide open of course. |
