Old 13th Sep 2008, 5:12 am   #1
elpasobooks
Default Circuit for switching power supply?
Does anyone have any suggestion about references to how to make a switching power supply for a vintage battery radio that takes 1.5 volts for the filaments and 90 vdc for the B+? (and perhaps just enough to run a quite pancake fan to cool the whole thing quietly....
Joe
KD5KZL
elpasobooks is offline
Old 13th Sep 2008, 8:48 pm   #2
Ed_Dinning
Default Re: Circuit for switching power supply?
Hi Joe, look at the Nat Semi website and also google Power Integrations; either will give you app notes and circuits for low powered, isolated, line convertors. Main problem is getting the LT stable and noise free. HT is dead easy.
Ed
Ed_Dinning is offline
Old 14th Sep 2008, 4:25 am   #3
elpasobooks
Talking Re: Circuit for switching power supply?
Gee, it helps to be using the right key word. And it is the ht I am concerned with most. The LT can come from a 12 CT transformer from RS.
73
Joe
KD5KZL
Old 14th Sep 2008, 11:16 am   #4
Ed_Dinning
Hi Joe, in that case if you have 12 volts simply make a cockroft-walton voltage multiplier to give a factor of , say, 10. Use 1n4004 diodes and 1uF caps and you should get 120v or so.
Or wire the transformer for 24 volts; then multiply by 5. Use a 1/2 wave rectifier on the CT to get about 12volts for the regulator for the heaters.
This is a far simpler system than using SMPS.
Ed
Old 14th Sep 2008, 9:18 pm   #5
dominicbeesley
dominicbeesley's Avatar
Hi Joe,
I made one a while ago with the attached circuit for the (1.4/2V) LT and a fairly similar circuit to the one here http://www.vintage-radio.com/project...y-set-psu.html for the HT (I wasn't bothered for regulated HT). The circuit is more or less a crib of the one on the TL494 application note but with no short-circuit protection, over/under voltage protection or soft-start
Not shown on the schematic - I wound the output + and - bifilar about 10 turns around a toroid before grounding the - to chassis and bringing the + to the output terminal for a bit of extra filtering.
You should be able to get a TL494 or AZ7500? from any older computer PSUs. None of the components were particularaly special, just what was in the junk box. It was certainly easier getting this to work than the circuit I've been working on recently!
Dom
PS: You may want to include a bit of an adjustment in the feedback from 1.4/2V as they don't come out exact (though they are stable) with the values on the diagram.
dominicbeesley is offline
