27th Dec 2017, 11:55 pm | #21 |
Re: New tape recorder Tandberg
28th Dec 2017, 1:33 am | #22 |
Play / Record switches in tape recorders can be as bad as, or even worse than, wavechange switches in radios, measuring by the sheer amount of grief they can cause. (I've never known a dodgy wavechange switch make me forget everything I ever heard on the radio .....)
That said, I've probably just been spoiled with three-head machines! There's nothing wrong in principle with a two-head recorder, if all the switch contacts are working properly; you can save a valve (two even, if you can forego listening through the internal speaker to the source material as you record), and there is something to be said for using the exact same head that recorded something to reproduce that recording .....
28th Dec 2017, 9:14 pm | #23 |
That sounds good, it's above 2209550, so hopefully very little will actually need to be done to the switches. Perhaps they just haven't been used for a while, so that just operating them several times may restore them.
