12th Nov 2018, 5:26 pm | #1 |
BSR SC11M and SC12H mounts
Hi all.
Just found these mounts on Ebay for the above mentioned cartridges. At £3.50 each they are a bargain. https://www.ebay.co.uk/itm/BSR-SC11M...mSn:rk:11:pf:0 Last edited by tracypaper; 12th Nov 2018 at 5:27 pm. Reason: Changed link |
12th Nov 2018, 6:04 pm | #2 |
Re: BSR SC11M and SC12H mounts
Make sure they are not too wide for your deck, you can also get narrow versions.
Cheers John |
12th Nov 2018, 6:05 pm | #3 |
Well spotted - interesting seller - cheers !!
'....don't go mistaking Paradise for that home across the road!' (Bob Dylan) |
25th Nov 2018, 6:19 pm | #4 |
I bought on of these clips. They fit BSR UA14 and similar tone arms fine.
Purchasers should note that the mounting hole is not threaded. It is just a hole that is approximately 2 mm diameter and was bigger than than original mounting screw. Incidentally does anyone know what size these are? |
