Old 11th Nov 2018, 4:44 pm   #1
19Seventy7
19Seventy7's Avatar
Default Garrard 2025TC circlip
I hate to ask this question as i’ve done it many times on other players, but how do you remove the circlip from a Garrard 2025tc turntable? The mat is glued down and there is a smaller metal ring around the spindle hole which seems to be blocking access. I know one issue could be that i dont have the special tool and i just use a small flat head screwdriver to prise it out.
Thanks
Edit: ive done it, i removed the mat and it came right off.
19Seventy7 is offline
Old 11th Nov 2018, 4:47 pm   #2
ben
ben's Avatar
Default Re: Garrard 2025tc circlip
gently pry away the metal trim, then it's a case of separating the 'teeth' of the circlip slightly and lifting up. Note carefully/photograph which way round it goes before removal!
Regards,
Ben.
ben is offline
Old 11th Nov 2018, 6:25 pm   #3
RojDW48
RojDW48's Avatar
For future ref (so you don't have to unglue the mat) the decorative round plate in the centre has 3 little lugs which slot into a recess in the mat itself - remove the spindle and pull the plate sideways to reveal.
'....don't go mistaking Paradise for that home across the road!' (Bob Dylan)
RojDW48 is offline
Old 11th Nov 2018, 10:06 pm   #4
19Seventy7
19Seventy7's Avatar
Thank you! I did think of that, but it just seemed to bend the metal. i'll definitely keep that in mind as it will need some cosmetic work in the near future.
Thanks
