Old 23rd Nov 2019, 10:13 pm   #1
Steve G4WCS
Steve G4WCS's Avatar
Default A pair of Icom bricks
Picked up an Icom 260E a while ago. Superb radios.
I keep browsing the internet for possible bargains and managed to get a 260A for £25 with a tuning fault. Its had a couple of nights spent cleaning it up, and its now putting the E to shame, off with its knobs into the dishwasher I think.
The beauty with having a couple is its easier to compare voltages as its probably a dry joint or an expired cap on the control logic board.
ID:	194261   Click image for larger version
ID:	194262   Click image for larger version
ID:	194263   Click image for larger version
ID:	194264   Click image for larger version
Steve G4WCS is offline
Old 24th Nov 2019, 10:04 am   #2
onewatt
onewatt's Avatar
Default Re: A pair of Icom bricks
Hi Steve,
I have a 260, think it’s also an “A” with a tuning issue. I struggled to find info on the circuit at the time so I put it on the back burner. I’ll be interested to see what you find.
ATB
Chris
G1rpo
BVWS, VMARS, RSGB, DEHS, RAOTA
Nothings too big or too heavy, otherwise it wouldn't be where it is!
onewatt is offline
Old 24th Nov 2019, 10:54 pm   #3
russell_w_b
russell_w_b's Avatar
I have a 260E too: great set. I replaced the meter lamp with a green LED when it failed, which was a bit of a fiddle, and the only trouble I've ever had was a dodgy connection on one of the board plugs which (as I recall) prevented me running CW on 1W. But that was a long time ago and it's been fine since.
Regds,
Russell W. B.
G4YLI.
russell_w_b is offline
Old 25th Nov 2019, 9:40 am   #4
Jon_G4MDC
Jon_G4MDC's Avatar
It's a pity that Icom have put up the manual minus the circuit diagram...
If you are still looking it can be found at mods.dk
It looks like the PLL runs on a 5.12 MHz crystal divided by 512 so PLL step frequency is 10kHz.
The mix down crystal is driven by a D to A to interpolate the 10k into 100Hz steps.
Are the tuning issues with the 10kHz steps or within each step?
Jon_G4MDC is offline
Old 25th Nov 2019, 11:38 pm   #5
Steve G4WCS
Ill keep you posted on my findings.
