15th Aug 2011, 4:32 pm | #1 |
Paraset - Phase 2
Hi all , Listen very carefully ...I will say this only once ! I completed my paraset / spyset project some time ago but can only operate from "HQ"
I manage to find vibrator so the set can be used with 6volt battery in the field (under cover ) The enemy is close by so my transmission will be short ! Both vibrators not working Iam thinking of building a "new" 6volt inverter inside this vibrator can ? Any suggestions welcome .... Will have to run .... Agent Dirk / ZS1VDB Last edited by Station X; 15th Aug 2011 at 5:17 pm. Reason: Linked images converted to thumbnails. |
15th Aug 2011, 5:18 pm | #2 |
Re: Paraset - Phase 2
I converted the images to thumbnails, because images can disappear from Photobucket etc. rendering a thread useless. Images uploaded to the forum will be here as long as the forum is.
15th Aug 2011, 5:20 pm | #3 |
This solid state vibrator, a joint design and construction project by forum members works fine for me:-
https://www.vintage-radio.net/forum/...ad.php?t=41944 You may need to make some changes for use on a 6V supply. Simpler designs are avilable, but they don't work for me.
15th Aug 2011, 6:20 pm | #4 |
I think VMARS have a design on their site that is used for military kit. or look at this:
http://www.qsl.net/g4bxd/wanted.htm Mike Last edited by MichaelR; 15th Aug 2011 at 6:29 pm. Reason: link added |
15th Aug 2011, 10:51 pm | #5 |
HI
Works for me just fine. Pete G4MRU |
16th Aug 2011, 12:05 pm | #6 |
Hi all , thank you for response . I will "go radio silence" to complete this project !
Hope high command has some transformers lying around in his shack Greetings Dirk |
