3rd Jul 2019, 5:48 pm | #1 |
SME3009 advice
A friend has dropped a lid on the arm. It has broken what I believe to be called a stabiliser bar. How is it fixed in, is it a new piece, if so what do I search for.
Many thanks. |
3rd Jul 2019, 5:59 pm | #2 |
Re: SME3009 advice
That's the bias lever that has snapped off - it's what the loop of the bias weight hooks over to provide anti-skating.
I'm not sure if the remains can be removed or if you can obtain replacements. Your friend might have to purchase a whole new upper bearing housing from someone who can provide parts. |
3rd Jul 2019, 6:08 pm | #3 |
Re: SME3009 advice
I have just found one on the auction site, it says SME 3009 S2 Improved Pillar & Yoke, I only need the yoke, so I have messaged the seller. I looks the same, but the one here says SME 3009, the one above is S2 Improved, it looks the same, not sure of differences.
3rd Jul 2019, 6:49 pm | #4 |
Re: SME3009 advice
The rod on the S2 is longer than that on the Improved, as the latter was designed for a maximum playing weight of 1.5g, so needed less bias than its predecessor, which was calbrated up to 5g.
3rd Jul 2019, 8:39 pm | #5 |
Re: SME3009 advice
Tried contacting SME?
4th Jul 2019, 12:13 pm | #6 |
Re: SME3009 advice
Ted, the arm here is a SME 3009, so I assume one of the earliest? If the one I am looking at is longer, it would be OK, tracking at 2g. I met a guy not long ago who knew all the models and differnces, I am still learning. At the moment the broken bits are a a engineers who maybe able to help, but need all my options open.
4th Jul 2019, 4:08 pm | #7 |
Re: SME3009 advice
The broken bias rod is from a Series 2 as produced from around 1962 to 1973, virtually unchanged. The Improved had the shorter bias rod and a counterweight on a threaded mounting, and some had a fixed headshell. Yours is a Series 2 on this evidence.
4th Jul 2019, 7:04 pm | #8 |
Re: SME3009 advice
Thanks. Makes sense now.
5th Jul 2019, 8:42 am | #9 |
Re: SME3009 advice
Give SME a call - they have lots of NOS spares, and might just have what you need. They are exceptionally helpful.
Craig |
