Old 29th May 2008, 10:52 pm   #1
FERNSEH
FERNSEH's Avatar
Default Beau Decca cabinet repair.
I'm repairing a Beau Decca cabinet for a Forum member.
The cabinet has a fair bit of woodworm damage.
The worst part is the left side rear cabinet foot and a wooden batten which is fitted between the left side front leg and the rotten rear leg.
DFWB.
ID:	17531   Click image for larger version
ID:	17532   Click image for larger version
FERNSEH is offline
Old 29th May 2008, 10:54 pm   #2
chipp1968
chipp1968's Avatar
Default Re: Beau Decca cabinet repair.
Good to see it being repaired. Is the rest stable enough?
chipp1968 is offline
Old 30th May 2008, 11:06 am   #3
FERNSEH
FERNSEH's Avatar
Hi Chipp,
I've removed all that remains of the side batten and there is a very sound base to fit the new parts. A new cabinet foot will have to be made.
DFWB.
FERNSEH is offline
Old 30th May 2008, 6:47 pm   #4
chipp1968
chipp1968's Avatar
The foot is shaped at the back as well as front presumably?
Old 31st May 2008, 11:38 pm   #5
FERNSEH
FERNSEH's Avatar
The replacement batten has been made and was fitted this evening.
The next job is to make the rear foot
DFWB.
FERNSEH is offline
Old 1st Jun 2008, 2:39 pm   #6
FERNSEH
FERNSEH's Avatar
I've decided not to make a new rear cabinet foot, the existing one is to be repaired instead.
DFWB.
FERNSEH is offline
Old 1st Jun 2008, 11:36 pm   #7
FERNSEH
FERNSEH's Avatar
The repair is almost done. I will apply a piece of veneer to cover up the join in the wood sections.
DFWB.
FERNSEH is offline
Old 3rd Jun 2008, 3:35 pm   #8
FERNSEH
FERNSEH's Avatar
The cabinet foot has been veneered and lacquered but the cabinet side does not look a pretty sight. There are lots of woodworm holes to fill.
DFWB.
FERNSEH is offline
Old 3rd Jun 2008, 5:54 pm   #9
tvden
tvden's Avatar
DFWB.
what are you going to do with the worm holes ?
tvden is offline
Old 3rd Jun 2008, 10:57 pm   #10
FERNSEH
FERNSEH's Avatar
Hi Den,
On this occasion I'm using wax to fill the holes.
The cabinet should be finished on Thursday.
DFWB.
FERNSEH is offline
Old 5th Jun 2008, 10:46 pm   #11
FERNSEH
FERNSEH's Avatar
The cabinet left side and the lid have been polished and looks a lot better now.
The camera flash tends to emphasise the woodworm holes. The only real answers to the worm problem is to replace the panels or glue new veneer on the damaged surfaces. Both this methods are very time consuming.
The set is to be delivered to it's owner on Sunday.
DFWB.
ID:	17684   Click image for larger version
ID:	17685   Click image for larger version
FERNSEH is offline
