Old 2nd Apr 2017, 8:56 am   #21
Wishiknewmore
Default Re: Problem identifying Sonolor radio
Ed
Thank you for that - if I go that route what wattage would the resistors need to be?
part of my problem is I do not know the circuit exactly, Herald 1360 found me the one below
http://85.144.220.212/nvhr/CristalGrandin_634.pdf
I have found a couple of others based on the same valve line up (see attached)
My list of capacitors based on observation is attached to post 13
One of the circuits shows the smoothers rated at 350v but its only a similar circuit not the actual one..
I do have a lamp limiter set up, but as yet not tried to power this set, perhaps overly cautious but I was going to replace the main smoothers and what I believe to be the audio coupler
But every time I sit down to source some replacement caps I either cannot find the exact (ish) ones and/or I get to a list that needs a small mortgage!
(and they may not be right)
Nuvistor has already helped me by suggesting what should likely be replaced and I have got the Y type as suggested by Herald1360
Perhaps I should get brave and power it up via the lamp limiter!
Any suggestions gratefully accepted
Philip
Name:	Rainbow 631 schema.jpg
ID:	140266   Click image for larger version
Name:	schema famial Radio rainbow 631.jpg
Wishiknewmore is offline
