Old 1st Dec 2006, 3:28 pm   #1
BassoonBloke
BassoonBloke's Avatar
Thumbs up Anyone fancy have a go at this......
Found this on the web, and i confess, i'm impressed.
Mind you the wirewrap stuff looks like a bit of a nightmare !!!
What do you make of it?
Alan.
http://www.homebrewcpu.com/
BassoonBloke is offline
Old 1st Dec 2006, 5:02 pm   #2
ppppenguin
ppppenguin's Avatar
Default Re: Anyone fancy have a go at this......
Masochist!
I've handwired a couple of fairly complex logic designs but not on this scale. Doing it in a FPGA makes it a lot easier because there's no wiring.
ppppenguin is offline
Old 1st Dec 2006, 5:22 pm   #3
paulsherwin
paulsherwin's Avatar
Wirewrapping like that was a standard prototype and short run production technique for digital stuff in the 70s and 80s. I remember the prototype of ITN's in-house graphics device VT80 was built that way around 1980 (hence the name, I think.) The boards looked pretty fearsome and I'm glad I didn't have to locate faults
Paul
paulsherwin is offline
Old 1st Dec 2006, 7:04 pm   #4
mikelect
mikelect's Avatar
I used to know a guy who worked for Texas Instruments UK who wire wrapped quite complicated processor prototypes while watching TV in the evenings
Mike
mikelect is offline
Old 1st Dec 2006, 7:51 pm   #5
Kat Manton
Kat Manton's Avatar
In my first job I wire-wrapped some quite large custom process control systems. With an electric cut/strip/wrap gun it's fast, too. I had an endless supply of little plastic thingies with pin numbers on; with the IC reference scrawled on in biro then shoved over the IC socket pins it was pretty easy to find my way around.
By "large" I mean a 19" card frame full of double eurocards, all wire-wrapped, with the backplane wire-wrapped as well.
With a schematic and the ICs and pins identified on the wiring side these things weren't too tricky to modify and repair, either.
Cheers, Kat
Kat Manton is offline
Old 1st Dec 2006, 9:14 pm   #6
igranic
igranic's Avatar
Mike,
Do you remember the name of the guy who worked for Texas Instruments?
I designed systems for TI that were protyped in wirewrap, so I almost certainly knew him. PM me if you prefer.
igranic is offline
Old 1st Dec 2006, 10:34 pm   #7
jim_beacon
jim_beacon's Avatar
The backplane of my 11/45 (http://www.g1jbg.co.uk/comp1.htm) is wire wrapped - there is a picture about halfway down the page.
Jim.
jim_beacon is offline
Old 2nd Dec 2006, 12:10 am   #8
PJL
For a while I did a bit of PDP11 programming for a manufacturing plant. As Kat says, wire-wrapping with the right tools is very quick. Somewhere I still have a box of wire-wrap IC holders with the long square pins.
PJL is offline
