24th May 2014, 8:10 pm | #1 |
Vintage RM Nimbus PC Graphics Problem
Hi
Can anyone shed any light on what is causing the graphics problem in my video below. http://youtu.be/eyoJPCgpIMs The computer is an RM Nimbus PC-186 manufactured by Research Machines in the UK in 1985. If you're not familiar with them, here is some background info. http://en.wikipedia.org/wiki/RM_Nimbus I am restoring a few of these and a few seem to have the same problem. There is no obvious problems on the motherboard, all capacitors look visibly OK. Any suggestions appreciated |
24th May 2014, 9:47 pm | #2 |
Re: Vintage PC Graphics Problem
Just for peoples' info, these were not IBM compatibles though they ran MS-DOS. They used an 80186 processor, the only 80s computer I know about that did.
I can't help with the video fault as I can't remember how the graphics subsystem worked. There was some oddball stuff in these machines, including a proper sound chip on the motherboard a bit like a Macintosh. Are you sure the monitor is compatible? |
25th May 2014, 12:14 am | #3 |
Re: Vintage RM Nimbus PC Graphics Problem
What monitor output are you using? The BBC connector or the "modified" CGA? Does the monitor work properly with a BBC? Have you got another TTL (digital) monitor you could try?
25th May 2014, 1:11 am | #4 |
These machines could be IBM Compatible, sort of, there was a file called runpc186.exe which allowed some IBM software to run. One of my machines has an IBM emulator board installed which allows it to be fully IBM compatible but for the most part they were designed to run native RM applications.
Its the original monitor, I've tried more than one. I have collected a few of these machines and a few have developed this particular fault while others are fine so there must be a weakness in the hardware somewhere. Its the CGA output. I have 3 of these original RM TTL monitors and its the same on all. I have other nimbus 186 machines that work fine on the same monitors the problem is only affecting a few of them. |
25th May 2014, 8:27 am | #5 |
My money would be on faulty graphics RAM chips - the regular striped pattern suggests it to me. Similar problems are very common on vintage video arcade games. I don't know the graphics hardware on RM machines but there should be a reasonably identifiable bank of RAM, either static or dynamic, for the display. Sometimes warming or cooling the chips can affect the fault and help to identify the faulty chip.
Chris
25th May 2014, 10:20 am | #6 |
If you post a picture of the motherboard or graphics card, I can probably identify the RAM chips.
25th May 2014, 10:24 am | #7 |
Agreed it looks like display memory.
If the memory ICs are socketed, try re-seating them. If that doesn't fix it, swap them around. If you swap over two working ones, the picture won't change; but if you swap a worker with the dud, then the fault will move and so the picture will change. You can work out which is the faulty one by elimination. If no pair of ICs move the fault when swapped, then suspect the address decoding or bus access logic.
25th May 2014, 11:11 am | #8 |
Thanks for the replies so far. Here is a photo of the mainboard. This machine has 1024kb RAM installed with 64kb Video RAM.
It looks like the chips are soldered to the board. |
25th May 2014, 7:22 pm | #9 |
Hi Valhalla, have you ever seen the failed machines displaying correctly?
Reason for asking is the scrambled display looks similar to that when more advanced software/hardware is being used, but it is not backwards compatible and thus cannot support an old monitor. Regards - Mike |
25th May 2014, 7:40 pm | #10 |
Looking again, it's almost as though not all the bits of each byte are getting through. Which -- unless there are eight one-bit wide memory ICs; I don't know exactly how the memory is arranged -- points to a faulty or dry-jointed bus transceiver IC.
Are there any "bodge wires" under the board that may have come adrift?
25th May 2014, 7:57 pm | #11 |
I reckon the video memory is the row of 8 identical chips at the top left of the board. They'll be standard 64k x 1 bit DRAMs. If you have, or can get, any spare chips, just piggybacking a known good one (no soldering) on top of each one in turn can often reveal the culprit.
Chris
26th May 2014, 2:55 pm | #12 |
Thanks Chris, I have ordered some chips so will see what happens.
On second glace, the fourth chip from the left isn't looking too healthy! |
26th May 2014, 8:28 pm | #13 | |
Chris
