29th Apr 2014, 10:44 am | #1 |
Dead Philips monitor
I've got an old Philips HD15 monitor. The screen is dead, the low voltages are OK, but there doesn't seem to be anything coming out of the HV transformer. I have only used a multimeter not a scope. Any tips would be greatly appreciated. Thanks
29th Apr 2014, 12:00 pm | #2 |
Re: Dead Philips monitor
What is the model number? It can usually be found on a label on the back.
29th Apr 2014, 12:20 pm | #3 |
Thanks Maarten.
It's a UTAP20W |
29th Apr 2014, 1:25 pm | #4 |
That doesn't seem right either. Maybe you could take a picture of the label?
29th Apr 2014, 1:32 pm | #5 |
Hi Marten
thanks for your time, it is appreciated. I've just looked at the label and that is the correct model number. It is a medical monitor but does have ordinary VGA DVI inputs. |
29th Apr 2014, 2:56 pm | #6 |
Ah, then it is most likely made by FIMI, Sarrono Italy (formerly known as Phonola, later part of Philips, nowadays part of Barco). Very high quality equipment and certainly worthwhile preserving (I own and use one of the very few consumer monitors they ever manufactured). Finding a schematic is probably going to be hard, so repairing must be done by traditional fault finding while reverse engineering or at least recognising the circuitry. This is best started at the power supply. Most likely it should be putting out a +B around 100V and some low tension lines to the signal and control circuitry. The horizontal deflection and HV transformer may be in separate circuits.
29th Apr 2014, 3:21 pm | #7 |
a quick web search gives this
HD15 - P/N: UTAP20W 4535 613 82311 20"lcd not one I have seen |
29th Apr 2014, 3:22 pm | #8 |
Yes Maarten, it is made in Italy. Havent been able to cct diagrammes, but will look for the 100v. Thankyou so much.
Yes Fixitnow, thanks |
29th Apr 2014, 4:08 pm | #9 |
Check the power transistor that is driving the primary of the horizontal output transformer. It may be s/c collector-emitter.
Al. |
29th Apr 2014, 4:40 pm | #10 | |
Rich
29th Apr 2014, 5:01 pm | #11 |
Thanks everyone
