24th Nov 2021, 8:45 pm | #1 |
Collaro 4T200.
Hi.
Just picked up this nice turntable today took a gamble as it was untested, I have a 2010 but this looked a bit cleaner as it was protected by a solid box. Anyway I just cannot get the mechanism to move, what is stopping the cam red arrow from moving? I shorted out the terminal where it the circuit completes when moved in white arrow and the motor runs fast and smooth which was good. |
24th Nov 2021, 9:59 pm | #2 |
Re: Collaro 4T200.
probably hardened grease, will need stripping cleaning and regreasing, Collaro are not the easiest things to work on
Being me is easy, its the image thats hard..ELVIS |
24th Nov 2021, 10:09 pm | #3 |
Re: Collaro 4T200.
Yes, that's right. It looks exactly the same as the speed change mechanism used on their Tape Transcriptor of the same vintage. That stepped cam will push a spindle (or pin, if you like) up that'll be totally solid with concrete grease. Don't try to force it or you'll bust it!
24th Nov 2021, 11:47 pm | #4 |
Re: Collaro 4T200.
I had the same problem with mine and sure enough hardened grease was the problem, the other problem mine had was that the turntable bearing was not much cop having had a hard life but otherwise a good deck and if the bearing is good then consider a modern arm and cartridge as the deck can take it.
25th Nov 2021, 12:06 am | #5 |
Re: Collaro 4T200.
Beautiful turntables! If you have trouble getting the speed change mechanism apart, try heating the relevant parts with a hair dryer to melt the old grease.
Barry |
25th Nov 2021, 4:43 pm | #6 |
Re: Collaro 4T200.
I expect you are aware of this - the speed change mechanism only works with the platter in place. I have just resurrected one of these - lovely TTs.
'....don't go mistaking Paradise for that home across the road!' (Bob Dylan) |
25th Nov 2021, 5:06 pm | #7 |
Re: Collaro 4T200.
Ah, a 'still life' but only a photographer who fixes stuff would fully appreciate it.
The speed knob removed from its shaft on the motor deck, the water-pump pliers beside it on the bench... David
25th Nov 2021, 5:32 pm | #8 |
Re: Collaro 4T200.
All good advice, excellent machines. Take care not to force the mechanism, specially the switch, as this can now be fragile and difficult to find a replacement. Change the capacitor across this switch, the deck is now 60 years old and if this has not failed it soon will.
Here is a pic of the same model deck, very kindly donated by Cre8anet last year. It took a long time to get to me with covid and travel restrictions but well worth it. Mounted in a Sapele plinth I made and fitted with a Rega R200 arm, it works very well and is a favorite. Alan |
25th Nov 2021, 7:33 pm | #9 |
Re: Collaro 4T200.
If you do decide to dismantle the mechanism take plenty of pictures before you start, it will make it easier for you when you reassemble. The switch on the Collaro I serviced was broken and I had to fabricate a new one, unable to source a replacement.
John |
26th Nov 2021, 6:34 pm | #10 |
Re: Collaro 4T200.
As this is becoming a 4T200 love-in here's mine
Arm shown is an Origin Live, but it's currently sporting a Rega R200. Last edited by wd40addict; 26th Nov 2021 at 6:43 pm. |
