14th Nov 2021, 4:53 pm | #21 |
Re: Autochanger to Bluetooth
Thanks. I get shopping and have a play.
14th Nov 2021, 5:07 pm | #22 |
With regards to the resistor, I meant 4ohm or 8ohm etc, not 4w or 8w. I imagine you realised but just in case
14th Nov 2021, 6:36 pm | #23 |
We need to know the Chip that RBM used. From that we might deduce the impedence load value
Edward. |
15th Nov 2021, 11:48 pm | #24 |
Does this look right?
16th Nov 2021, 8:21 am | #25 |
My 2p. The potentiometer is a voltage divider, you probably need to drop the voltage about 5 to10 fold depending on how many watts the record player outputs.
What BT module are you using and how are you going to power it? |
17th Nov 2021, 9:44 am | #26 |
I thought initially I would feed this signal directly into my BT speaker at a very low level and experiment until I was satisfied there was adequate signal without distortion. Would that work the way I've drawn it?
I'm thinking if it does, then I can install the transmitter afterwards. Cheers! |
17th Nov 2021, 9:47 am | #27 |
Ah, sorry. I've just seen your suggested circuit.
19th Nov 2021, 3:12 pm | #28 |
Have I really got a 12 ohm speaker?
19th Nov 2021, 6:05 pm | #29 |
Well that certainly looks like it.
Edward. |
19th Nov 2021, 8:35 pm | #30 |
You will need a 12ohm 50 W resistor.
https://www.ebay.co.uk/itm/50W-Alumi...-127635-2958-0 |
20th Nov 2021, 12:07 am | #31 |
Why 50W? That amplifier looks capable of about 1W tops judging by the output transistors. A 3 or 6W part would be plenty.
20th Nov 2021, 8:24 am | #32 |
It is a transistor amplifier and will work without a load, probably better than with.
20th Nov 2021, 4:19 pm | #33 |
21st Nov 2021, 9:18 pm | #34 | |
Merlin speaks wisely. I fear you're in danger of overthinking this A simple potentiometer across the output, if its a high ish resistance, say 10k the power amp probably won't develop any great amount of power so you are unlikely to get the pot war.m. If you're really that nervous then get a 15ohm or thereabouts resistor rated at the amps output and bung that across the output, then a polyester capacitor, say 1uF at 22V or better onto the top of a 10k pot and the wiper to your BT input. Have you got a copy of the circuit for us to look at? A. |
22nd Nov 2021, 8:17 pm | #35 |
Hi all.
Thanks for all your input. I can't find a cct diagram for my little Dansette and I really don't mind that my player has a tiny speaker and an amp to match, hence the Bluetooth query. I would appreciate any suggestions to extract an output from the amp in a diagram form, as I can read a diagram, even if I can't draw one correctly ;-) As I haven't done much restoration, I don't have a workshop full of components so I've ordered the parts for Gabriel's potentiometer circuit, as this seems the simplest solution for a novice like me. As I said, if I can hard wire the amp o/p to my BT speaker, I can worry about the wireless aspect later. I just don't want to damage anything achieving a suitable signal. |
22nd Nov 2021, 9:10 pm | #36 | ||
23rd Nov 2021, 9:16 am | #37 |
The picture in post #28 shows a transistor amplifier which looks identical to that in the Bush RP73.
https://www.service-data.com/section.php/9580/1/rp73
23rd Nov 2021, 11:25 am | #38 |
Re: Dansette Apollo to Bluetooth.
Which indeed has a 12ohm speaker and an output capability of maybe 1.5W.
(3W music power quoted.)
23rd Nov 2021, 5:44 pm | #39 |
No wonder the OP wants to play it on a different speaker.
So, RMS output x2 = "music power"? Lol |
24th Nov 2021, 6:47 pm | #40 |
So I've downloaded the cct diagram ( thanks for the link), and some bits have arrived. I've got a 12 ohm 10 watt wire wound cement resistor. No capacitor yet but I have a 100k trimmer pot thinking once it's set, I shouldn't need adjustment. I didn't realise it would only be 1/4" square! It was unrated so I'm concerned as to whether it will get hot/ melt? It could form the start of a collection of spare components
I could post a screen dump of the cct diagram if that's not breaking any forum rules? Thanks again! |
