Old 17th Nov 2017, 11:03 pm   #1
jamesinnewcastl
jamesinnewcastl's Avatar
Default Matching Paint Colours
Hi All
I don't know if this is useful or widely known about but as I am restoring some WW2 radio equipment I needed a paint that matched the original.
Nothing suitable in the standard range nor in the RAL or other standard swatches and of course there is no useful way to match a colour using a computer screen.
While you can get home decoration paint matched by taking a sample into a store this only gets you emulsion or gloss paint!
However I found a company on line that will match a sample paint colour and give you spray cans of paint suitable for metals.
Attached is a photo of the result - the paint was sampled by sending the small box capacitor to the company. I used this as it had been inside the enclosure for 65 years and so hadn't faded. In the photo the spray paint was applied in the area roughly enclosed by the red line. It's a very good match I think.
I'm not associated with the company but if you can't find someone offering the service PM me and I'll give you the URL of the one I used.
James
jamesinnewcastl is offline
Old 18th Nov 2017, 12:40 am   #2
Craig Sawyers
Craig Sawyers's Avatar
Default Re: Matching Paint Colours
I've used Paints4u to match not only colour but also mattness. You just need to send them a sample. I use it to restore casework in classic Tektronix test equipment.
https://www.paints4u.com/
Craig
Craig Sawyers is offline
Old 18th Nov 2017, 10:46 am   #3
60 oldjohn
Most large towns have an Auto parts /paint supplier that will be able to mix your specimen colour into an aerosol.
John.
60 oldjohn is offline
Old 18th Nov 2017, 6:20 pm   #4
That's what I have done in the past: such places are quite adept at getting a colour match to old, faded/over-T-cutted car bodywork and will generally be able to match what you give them.
Only problem is, the car body-paints [acrylic, cellulose] of old are rapidly being displaced by water-based stuff for environmental reasons: unfortunately these paints just don't work as well as the old ones.
Old 18th Nov 2017, 8:25 pm   #5
Panrock
Panrock's Avatar
I thought modern acrylic aerosol was water based. Certainly, it doesn't merge in well at the edges with the two-pack already on my car.
Steve
Panrock is offline
Old 18th Nov 2017, 8:33 pm   #6
jamesinnewcastl
Hi
Interesting about 'colour matching', I've been looking around and I'm not sure that there is clear distinction in the ads between 'analysing and producing a bespoke formula' and 'matching' to the closest in our existing colour range. I assume the company I used had a colour analyser to produce a specific receipe.
As I went to pick the paint up myself (as they had made a mistake previously) I watched them doing the mixing. Very interesting - they had paint pots with trigger operated lids that allowed them to drop in precise gram weights of many different thick colour paints into a clear base. The mixture was on scales and this was reset for each colour. Mixed by hand then poured into an aerosol can, next a cap was put on and propellant pumped in.
James
