13th Nov 2015, 10:56 am | #1 |
Unknown switch
Hello
Can anyone throw any light on what this switch is from please. It is a six way switch and rather well built. Many thanks Jonathan |
13th Nov 2015, 12:47 pm | #2 |
Re: Unknown switch
Judging by the size of the connectors its a fairly high current switch, perhaps an electric cooker or other heating device?
Peter |
13th Nov 2015, 2:02 pm | #3 |
Re: Unknown switch
Hi Peter
Thanks for reply, have just noticed it has stamped on a lug, GIEME (MOD arrow under that) and then CS2 under that. Kind regards Jonathan |
13th Nov 2015, 3:05 pm | #4 |
Re: Unknown switch
I can't identify it specifically but that type of rotary switch was fairly standard on all sorts of industrial equipment and control gear for many decades. Within 10 feet of where I'm standing there are similar examples on a large battery charger, a lathe, and a cine projector control box.
13th Nov 2015, 3:16 pm | #5 |
Re: Unknown switch
I recall those kinds of switch being fitted on water-boilers in commercial kitchens and wired to switch 2 heating elements in different series/parallel combos depending on the heat required.
Off Slow [1 element only] Fast [2 elements in parallel] Simmer [2 elements in series]. |
13th Nov 2015, 3:29 pm | #6 |
Re: Unknown switch
The unit construction means that they could be stacked up to switch several poles simultaneously (and at the same time), a bit like wafer switches. The names 'Diamond H' and 'Square D' spring to mind, but I'm certain other makers did them too. There's a couple on this ex-military charging board. Cheers, Pete.
"Hello?, Yes, I'm on the train, I might lose the signal soon as we're just going into a tunn..." Last edited by Tractorfan; 13th Nov 2015 at 3:34 pm. Reason: Added a photo. |
13th Nov 2015, 3:32 pm | #7 |
Re: Unknown switch
They have a very stiff, sprung snap-action so contacts close and open quickly, however slowly the handle is operated. They were designed to quickly stop arcs and to last indefinitely.
All sorts of makers made them in all sorts of formats. David
13th Nov 2015, 4:17 pm | #8 | |
Re: Unknown switch
13th Nov 2015, 4:34 pm | #9 |
Re: Unknown switch
I've a similar one here, made by Santon Wales UK, rated at 40A 250Vac. It has 4 positions and is continuously rotatable. I rescued it from the scrap pile during a ship re-fit.
Regards Mike A |
13th Nov 2015, 4:35 pm | #10 |
Re: Unknown switch
Santon were also a maker of these excellent rotary switches.
Leon. |
13th Nov 2015, 5:07 pm | #11 |
Re: Unknown switch
As a matter of fact, one of these acts as a master switch for my workshop supply, housed in a box together with RCDs.
A simpler, standardised version was for many years used on cookers, to enable series / parallel switching of elements. Useful for a lot of other projects, too - I still have a few knocking around. |
13th Nov 2015, 5:26 pm | #12 |
Re: Unknown switch
A Santon example serves as the direction switch of EK's 1967 Lansing forklift. It's in the housing arrowed and fitted with a miniature 'gearstick' lever instead of a knob. You can hear me operate it at 0:21 in this clip...
https://youtu.be/2M79FmIHScQ |
14th Nov 2015, 9:13 am | #13 |
Re: Unknown switch
Many thanks for all the replies.
The switch is one of six switches that came in a junk box. Two of them are glove heater switches from aircraft: found here http://spitfirespares.co.uk/Electrical%20Switches.html Of the others, one is a TOK, and one is a Santon SR127, which I believe was used on Myfords at manufacture. |
6th Jul 2016, 3:04 pm | #14 |
Re: Unknown switch
That looks similar to the switch (speed) on a Compton Woodworking Lathe we had at school when I was a Kid. I've seen similar ones still used on heavy duty equipment these days. The contacts are probably Berylium Copper alloy.
