Old 25th Mar 2013, 6:17 pm   #1
sentinel040
Location: Near Lichfield, Staffordshire, UK, most of the time and Crystal Palace, S London, some of the time..
Default Cleaning printed brass tuning scale
I have been recently sorting out a discriminator fault on a GEC BC403, which had been aided and abetted by the phantom twiddler at some point in the past. Sometime last year I stripped the case and repainted the speaker grille etc and removed all the embellishments. At the edges of the front panel are (or were until I removed them) brass strips, a plain one each side to the outside and in-boards of that a printed one, with red letters or numbers on a plain brass background. The left hand side bears the tuning scale and station names and the right hand one the words "Tuning" and "Volume". The right hand one is not too bad but the left hand side is very badly tarnished - or should that be patinised.....
I have been considering this on and off - admittedly more off than on - for some time but cannot think of a way to clean the brass that will not risk damage to the red printing.
Another point is that there is some form of very localised corrosion, the appearance of which is a bit like rust spotting, but on brass.
Does anyone with experience of this sort of thing have any good ideas on how to clean these up?
Regards
Ian
sentinel040 is offline
Old 26th Mar 2013, 11:30 am   #2
brenellic2000
Default Re: Cleaning printed brass tuning scale
If the printing is by gold size then avoid solvents as they will lift it very quickly unless it has been well lacquered. Soapy water is probably best. Strictly speaking 'patina' applied only to copper carbonate 'oxide' on copper based alloys but has been widely mis-used to describe aging. OAP 'old aged patinas'... hmmmm!
TTFN
brenellic2000 is offline
Old 26th Mar 2013, 6:20 pm   #3
sentinel040
Thank you for that.The printing is in red and must be fairly resilient to withstand daily wear and tear, the use of patina was supposedly tongue in cheek, taking the proverbial Michael if you like, but perhaps a little too subtle . Some of he brass strips are very deeply discoloured, if it these had been lacquered it must have worn off, the fact that some have discoloured and others have not points to a late 50's / early 60's GEC quality control problem with the protective coating. It looks like there is little that can be done
If had been bits of a steam engine I would have thrown it in a bucket of Coke or for the really grubby bits old battery acid!
Ian
Old 27th Mar 2013, 11:44 am   #4
brenellic2000
That is the major problem with lacquer - once applied it can be nightmare as once broken, it allows creeping oxidation underneath which needs the lacquering to be totally removed!
Has the brass been etched to receive the cliche printed lettering, or is it surface applied as if screen printed? If etched, it can be restored... but its labourious work!
Old 27th Mar 2013, 12:53 pm   #5
Radio_Dave
Radio_Dave's Avatar
I've just Googled some pictures of this radio and I'm not convinced it's brass. Have you tried a magnet on it to see if it's some sort of gilded steel?
Radio_Dave is offline
Old 27th Mar 2013, 1:04 pm   #6
RogerWalker
RogerWalker's Avatar
Question Re: Cleaning printed brass tuning scale
I have a similar problem with a etched/lacquered brass dials for the Cossor 343 ganging oscillator I'm restoring - see photos. Any advice on how best to restore these will be gratefully received.
Regards
Roger
ID:	77909   Click image for larger version
ID:	77910   Click image for larger version
RogerWalker is offline
Old 27th Mar 2013, 10:07 pm   #7
sentinel040
Brenellic2000, unfortunately (and my impending doom alarm is starting to sound) it is printed rather than etched. It is a rather cheap radio from the latter years of the valve era.
Dave, it is indeed non-ferrous, a check with a mag mount some time ago proved that point rather well.
Thank you for your helpful comments so far.
regards
Ian
Old 28th Mar 2013, 11:36 am   #8
brenellic2000
You may be lucky and still be able to find 'Letraset' (or its equivalent) in a suitable font, otherwise its a case of printing onto self-adhesive clear laser-film or transfer film.
Good luck!
