| Components and Circuits For discussions about component types, alternatives and availability, circuit configurations and modifications etc. Discussions here should be of a general nature and not about specific sets. |
#21 |
So after taking your collective advice, today I received a 12.8 V 50 Ah lifepo4 from Eco Worthy.
I connnected it to our tent solar PV array, and had it charging merrily at 7A in decent afternoon sunshine! It is a very nice battery, double the capacity and half the weight of the previous sealed lead acid. It states that it can take a continuous charge and discharge of up to 50 A! Mental! I will test it over the weekend, running our camping fridge that I recently rebuilt using Peltier heat pumps, I gave this a variable current control, so can fiddle about, but may automate this load against sun intensity and battery charge.. a diode least gate may be of use here. Cheers, Scott
www.scottbouch.com |
#22 |
PS, this battery includes its own internal BMS in the casing to manage the cells internally. Shame the top is glued/bonded on as I'd have liked to see inside!
it comes with a nice little carry handle too fitted in the top, which may seem an odd feature to emphasise, but when you have to reach deep into the camping trailer to fetch it out, little things like this do help!
#23 | |
Paul |
#24 |
I've generally had good results from sealed lead-acid batteries. Though they do have their limitations...
Overcharging leads to gassing, possible venting of the seals, and permanent loss of electrolyte. So, charge voltage needs to be carefully controlled, and compensated for the ambient temperature (memory says 2.5mV per °C per cell, so that's a change of float voltage of 300mV for a 12V battery for a temperature range of 5 - 25°C. It's not negligible). A second degradation mechanism is leaving discharged. As the lead-acid cell discharges, the active material on both plates turns to lead sulphate. But left thus, the fine-structure of the sulphate slowly crystallises. Because lead sulphate is a poor conductor of electricity, it is very difficult to return to the lead, and lead peroxide, of a charged cell. So, as soon as possible on discharge, put back on charge. And if you can't, then keep the battery cold - low temperatures slow down the crystallisation process. Recovery from loss of electrolyte is only possible if you can add more. Recovery from sulphation is possible to an extent, by slow charging from a high voltage until the battery is accepting a charge, and then several charge / discharge cycles. |
