| Components and Circuits For discussions about component types, alternatives and availability, circuit configurations and modifications etc. Discussions here should be of a general nature and not about specific sets. |
#1 |
I've just repaired a rather handsome Technics SA-200 tuner-amp - both STK 0029 modules were faulty (o/p short to +ve HT) .
I therefore built a couple of "discrete" versions mounted on an aluminium bar, and the amplifier now seems to work to spec (power / distortion). I've posted the schematic in case anyone else has a similar problem - the 0029 is one of a series of hybrid circuits with pretty much identical topologies. NB the bias current was set to give 30mV across the two 0R27 resistors, i.e about 50mA. T1 is mounted between the output darlingtons to provide good thermal tracking. John
When you don't know what you are doing, do it neatly. |
#2 |
Clever stuff, John. There are a lot of nice bits of kit from the late 1970s around which use these modules. When they were plentiful, repair was quick and easy and not expensive. Now it's a gamble unless you resort to what you've done.
Any more photos? |
#3 |
Now my shoddy work is on view!
#4 |
No, that looks spot-on from here.
I wonder whether there's a commercially-available PCB for this kind of job? |
#5 |
looks good enough to me!
Kevin |
#6 |
Well done!
Looks great to me.
#7 |
Does the job. What's not to like? - And much better than a pretty little amp chucked in the skip. This could easily be more reliable than the original.
#8 |
#9 |
Great work there John, well done for saving an attractive and useful piece of kit that likely otherwise would have been declared BER and parts unavailable. The recent hifi receivers thread highlighted the esteem that this era of audio is held in by many here. Perfectly functional and effective repair that will last and last, probably with better heat transfer than the original,
Colin |
#10 |
These are the deceased amps - not a matching pair, and the one on the right failed the Isoprop test! The soldering on the pcb showed no indication of recent activity.
#11 |
It is likely genuine, there are various kinds of printing. The numbers on the back should be plausible as well, though I don't know every detail of those.
#12 |
Well done. Looks great and does the job.
Aub
Life's a long song, but the tune ends too soon for us all - Ian Anderson, 1971. |
#13 |
Lovely, what a great solution
Paul |
#14 |
John, I just want to say thanks for the info on the STK0029 replacement.
After a few attempts (I'm not an electronics whizz by a very long way so there was some, um "hard learning" along the way) I managed to restore my mother's Technics SU 8011 that had a faulty left channel. The STK0029 was the culprit. I couldn't get hold of the transistors in your design so I used a BDW93C paired with a BDW94C in place of the TIP102 / TIP107 pair. T1 was a BD139 mounted to the heatsink between the pair as you suggested. For some reason I found that the value of the 390R had to be increased to 500 to get it to bias ok. I found it biased correctly at a setting of 660-680 ohms (500R + the 200R trim pot) when measuring across the bases of T1 and T3. I replaced the other STK with a duplicate discrete circuit as well as the filter caps (these seemed to be original!) and now the unit is back in working order. Anyway, just want to say thanks again. |
#15 | |
Daniel: glad you were able to fix it!
BTW, Quote:
Bias voltage will be slighly different due to change of darlingtons. John
#16 | ||
I don't have any sophisticated equipment so I initially biased it using a dim bulb tester adjusting the trim pot until the bulb went completely off (this after I lost a few sets of transistors that went straight into thermal runaway until I tried this trick). Then I ran it directly off the mains and did some fine adjusting until the voltage across R4 and R5 was in the 15-30mV range. |
