Old 23rd Jan 2021, 7:36 pm   #1
Jon_G4MDC
Jon_G4MDC's Avatar
Default Any ID on this inductor please?
Here is a part recently removed from a CFL fitting of about 20 yrs ago.
It is the type where the tube had a base consisting of 4 four pins arranged around a square spigot. The tubes themselves were two side by side and U shaped, maybe 6" long. There were lots of these CFLs around but I forget which brand was on them, GE possibly among others?
Inside the lampholder was a PCB, it has bridge rectifier feeding some 22uF 200V capacitors in series and some Sw_mode trickery following. Good to harvest for parts.
I am interested in the input filter inductor. It looks like this. Two pretty identical windings wound on an ungapped(probably) ferrite core .
Any ideas what the ballpark inductance of this might be please?
My facilites for measurement of inductance are lacking.
ID:	225240   Click image for larger version
Jon_G4MDC is offline
Old 23rd Jan 2021, 8:04 pm   #2
Default Re: Any ID on this inductor please?
I guess it's a common-mode RFI-suppression choke, with the 2 windings intended to sit in the L and L supply-lines.
Old 23rd Jan 2021, 11:51 pm   #3
Terry_VK5TM
Terry_VK5TM's Avatar
Not knowing the design details, it is going to be hard to say without being able to measure it.
To give you an idea of the possible range, I looked up Coilcrafts common mode filters and the inductance values vary between 130uH and 45 mH.
That is only indicative, other manufacturers could be very different.
Terry VK5TM
https://www.vk5tm.com/
Terry_VK5TM is offline
Old 24th Jan 2021, 11:05 am   #4
Jon_G4MDC
Jon_G4MDC's Avatar
Thanks both, yes that's what it is. I'm going to try and guess the inductance by adding a capacitor and looking for resonance.
Old 24th Jan 2021, 12:41 pm   #5
Julesomega
Julesomega's Avatar
3.9mH
Name:	CFL L [1].jpg
- Julian
It's good here
Julesomega is offline
Old 24th Jan 2021, 12:48 pm   #6
Julesomega
Julesomega's Avatar
Another example, 3.5mH
These are from smaller CFLs than yours, I think
Name:	CFL L [2].jpg
- Julian
It's good here
Old 24th Jan 2021, 1:37 pm   #7
Julesomega
Julesomega's Avatar
Larger CFLs may have much lower inductance chokes: this one is from a CFL with three U-shaped tubes, rated at 20W. The inductance measures only 0.15mH, though that makes me suspicious that it has shorted turns
Name:	CFL L [3a].jpg
ID:	225269   Click image for larger version
Name:	CFL L [3b].jpg
- Julian
It's good here
Old 24th Jan 2021, 2:58 pm   #8
Julesomega
Julesomega's Avatar
I must correct my last post: the inductor is tapped. The former broke up as I removed it so I don't know how the two turns were connected, but it may have had a lot more inductance with the turns in series
Oh, btw, I do love this android app Magnifier Plus, it's better than a loupe for seeing small details, plus you can save the images
Name:	CFL L [3c].jpg
ID:	225272   Click image for larger version
Name:	CFL L [3d].jpg
- Julian
It's good here
Old 24th Jan 2021, 3:12 pm   #9
Julesomega
Julesomega's Avatar
More on this inductor: the core has a much greater air (glue) gap than the others, about 0.2mm compared with a layer of thin superglue on the others. From this I conclude that it was for a smps operating at high frequency, and nothing to do with RFI suppression
- Julian
It's good here
Old 29th Jan 2021, 8:05 pm   #10
Al (astral highway)
Al (astral highway)'s Avatar
That's really handy, Jules! Looking forward to using that!
Al
Old 30th Jan 2021, 11:05 am   #11
Jon_G4MDC
Jon_G4MDC's Avatar
Agreed, that magnifier is really useful.
No more done with the inductor but thanks for all the inputs.
