| Vintage Audio (record players, hi-fi etc) Amplifiers, speakers, gramophones and other audio equipment. |
#1 |
I have built a Mullard 33 amplifier. When I go to turn it off I get a load pop in the speakers. To prevent this I straddled the mains switch with an X capacitor. That fixed it. However I think that is a bad solution. If the cap becomes leaky, one might get a shock still when the switch is off. Any ideas how I could solve this please? John |
#2 |
Its not a real problem loads of amplifiers have a suppressor capacitor across the switch ! You have to unplug while working on the amp
Trev |
#3 |
X capacitors don't go leaky! They are designed to lose capacitance slowly as they absorb spikes on the mains and eventually go open circuit. If you have used a proper X capacitor , you won't have any problems. Most of the current manufacturers make decent X capacitors, the likes of Epcos and Wima.
#4 |
Though I have seen a piece of gear switch itself on for a couple of seconds before smelling that familiar smell of a smoking Rifa capacitor.
#5 |
I think modern Rifa's are fine. The older translucent types absorbed moisture over time through microcracks that appeared in the plastic. I'd still avoid them though....
#6 |
Suppressor capacitors can have longer lives with a bit of series resistance to limit transient currents. Acts as an R-C snubber. Trying to tame transients with pure capacitance just reflects most of the energy to bounce around until it finds something unplsnned to dissipate in.
Decooupling and suppression is an art! David
#7 |
Wiring that capacitor in series with a 100 Ohm resistor, across the mains transformer primary would be a better option.
#8 |
Rifa used to supply them with an inbuilt series R many years ago
Ed |
#9 |
Correct, they were known as 'Snubber' capacitors.
I still use them, & have no problems. David, |
#10 |
Thank you all.
I feel a bit better now. I will also try the 100 Ohm snubber across the transformer primary. John |
#11 |
Exactly what was used in my old Akai hi fi amp. The capacitor did fail however (microcracks again) and I replaced it with a standard X cap and a 100 ohm resistor. 40 years later, it's still OK
