Old 2nd Dec 2025, 12:20 pm   #1
KeithsTV
KeithsTV's Avatar
Default Mystery MSF receiver
I've recently acquired an MSF clock built by my father-in-law many years ago. It came in two cases, a receiver and the decoder display. It works but there is a fault in the display which I think is the actual 7 segment displays but having opened up the case it looks like a CMOS logic IC based decoder and looks a "mess".
However the receiver looks as if it was a magazine project and has what I assume is a professionally produced PCB. I'd imagine it would have been published in the 80's.
Can anyone identify the PCB and suggest in which magazine it was published or point me in the right direction for the circuit as I'd like to reuse the receiver with a more modern decoder.
Keith
ID:	322231   Click image for larger version
KeithsTV is offline   Reply With Quote
Old 2nd Dec 2025, 2:10 pm   #2
turretslug
turretslug's Avatar
Default Re: Mystery MSF receiver
Ambit published a design for a two-part MSF clock (receiver and decoder/display), the "Rewbichron" in the early '80s in Radio and Electronics World- they were also agents for Toko coils.
turretslug is offline   Reply With Quote
Old 2nd Dec 2025, 2:25 pm   #3
I wonder if the name Rewbichron hints at it being a circuit from Radio and electronics World magazine?
If so, scanned copies of said mag are available at the American Radio History site.
"It's not true that I had nothing on. I had the radio on!" -Marilyn Monroe .
Old 2nd Dec 2025, 7:21 pm   #4
KeithsTV
KeithsTV's Avatar
I'm pretty sure that it's not the Rewbichron as that receiver is a single IC superhet whereas this receiver looks like it's a TRF.
Also the Rewbichron decoder uses a micro whereas this one is discrete logic ICs.
I suspect I'll have to trace out the circuit.
Keith
Old 2nd Dec 2025, 7:23 pm   #5
KeithsTV
KeithsTV's Avatar
There is also an MSF receiver shown in the 98/99 Maplin catalogue but that one is also a superhet.
Keith
Old 2nd Dec 2025, 7:39 pm   #6
TonyDuell
There was a Rewbichron II which had a single-chip receiver (that I could never get to work properly) and a Z80-based decoder/display. I got the kits from Cirkit back in the late 1980s.
Maplin published at least 2 designs for MSF receivers in their magazine. I built the earlier one which, IIRC used an NE567 to detect the 60KHz signal. That one worked fine after I'd replaced the capacitor associated with said PLL with one that had a low temperature coefficient. The one in the kit would drift so far as to prevent the thing from working with a soldering iron held about an inch away. I think the later Maplin design was a superhet.
The board in this thread is none of those. If there was an earlier Rewbichron then it might well be that one.
TonyDuell is online now   Reply With Quote
Old 3rd Dec 2025, 12:22 pm   #7
KeithsTV
KeithsTV's Avatar
I've just had another look at the receiver and it looks as if it is a superhet. The single Toko coil is the local oscillator running at around 64kHz giving an IF of about 4kHz. There is an audio output from one of the op amps with the second op amp acting as a detector with a square wave output to feed the clock.
Time to start drawing out the circuit.
Keith
Copyright ©2000 - 2025, vBulletin Solutions, Inc.
Copyright ©2002 - 2025, Paul Stenning.
