Old 4th Jul 2020, 5:01 pm   #21
eddie_ce
eddie_ce's Avatar
Default Re: UK Homebrew Dummy Load plans
Years ago, I made a dummy load out of 20 carbon resistors, each 1k 3w in parallel. These were soldered vertically and equally spaced around the diameter between two copper discs approx. 2,5" in diameter, The SO239 connected to each disc.
The whole thing was immersed in a treacle or similar tin filled with transformer oil, a canister of which I blagged from a mate working for the electricity board. It worked perfectly with a good VSWR at least up to 2m. Although not designed for 100% duty cycle it was more than sufficient for tuning my TS820S.
Eddie
BVWS Member.
Friend of the BVWTM
eddie_ce is offline
Old 4th Jul 2020, 5:51 pm   #22
m0cemdave
More recent Bird loads use a Silicone oil. Rather expensive in small quantities, I think it's one of the (guaranteed non-toxic) types used on food processing machinery.
It has to be the correct viscosity. I used to have the spec somewhere, but seem to have lost it.
m0cemdave is offline
Old 4th Jul 2020, 6:24 pm   #23
These days, I'd use modern 'slab' resistors coupled to a fan-cooled heatsink.
A couple of decades ago "KDI" was the brand to look for - though beware that a lot of those offered on the world's-favourite-tat-bazaar are either fake or are recovered-from-failed-equipment scrap.
KDI were bought out by "Aeroflex" which in turn became "Inmet".
https://www.apitech.com/brands/inmet...l/inmet-brand/
who could be worth a call if you want a good dummy-load.
Old 4th Jul 2020, 6:41 pm   #24
G0HZU_JMR
The other way to do it would be with graded 50R attenuator sections. This would distribute the heat better and the coolant oil wouldn't be needed. Just a big long heatsink with the flanged attenuators mounted along it in series. It might be possible to buy 1dB, 2dB...10dB flanged attenuators at a reasonable price on ebay. I have a Bird 40dB attenuator that uses this principle and I think it is rated to 1.5kW up to 2GHz without needing any cooling oil. It does mean that you have to be careful to always feed the high RF power in at the correct end or the attenuator would be damaged very quickly.
Regards, Jeremy G0HZU
G0HZU_JMR is offline
Old 4th Jul 2020, 8:22 pm   #25
David G4EBT
David G4EBT's Avatar
Originally Posted by Cobaltblue View Post
I have a couple of large tubular carbon resistors you can have for the cost of postage if you want to experiment
They are hollow 250mm long 25MM outside diameter
They are shown as 66 Ohms
They can be posted Via Hermes for £2.90
Mike T
They're conductive throughout their length of course so if the termination clips at either end are adjusted, each of the resistors could be set to 50 Ohms and make two perfectly adequate dummy loads if just used for ten seconds or so at a time when tuning up off air. It's a rather more polite than using the mike as some 'Billy no mates' do (or did when I was on air) bellowing 'Ahhhhhhhlow' into the mike and while tuned up, then with everything tweaked, calling CQ and expecting someone to answer them. I don't think so chum.
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is offline
Old 4th Jul 2020, 8:25 pm   #26
A common problem with commercial RF power attenuators.
Some don't say that the dissipation is asymmetric, you just have to be suspicious. Lucas-Weinshel made a thing about symmetry
DAvid
Radio Wrangler is online now
Old 5th Jul 2020, 12:04 pm   #27
Andrew B
Andrew B's Avatar
I made a load from 20 1K 3W resistors arranged in a ring, this got put into a "Tate & Lyle" syrup tin (other types available) and 3/4 filled with sunflower cooking oil, good to 180 degrees C
worried about the electrons entering the circuit and the smoke leaving
Andrew
Andrew B is offline
Old 5th Jul 2020, 2:11 pm   #28
Your_Sinclair
Originally Posted by Terry_VK5TM View Post
Mineral oil, paraffin of any type is the last thing you want in an enclosed tin with a heat source
https://k4eaa.com/dummy.html
No worries, as I rent my house, I will exercise extreme caution.
Your_Sinclair is offline
Old 5th Jul 2020, 2:12 pm   #29
Your_Sinclair
Some of the high frequency termination resistors have a very low duty cycle and get very hot very quickly.
There's an interesting article "Building a Dummy Load" by Ken Kemski, K4EAA on the net, in which he uses 20 off, 1k, 3W metal film resistors, which he immerses in liquid paraffin (as used with horse and ponies) in a 1 litre paint tin.
B
Sounds interesting and I am planning on reading the article later on tonight.
Old 5th Jul 2020, 3:08 pm   #30
Your_Sinclair
Agreed, I don't want to start making enemies before I even start my initial CQ.
Old 5th Jul 2020, 6:03 pm   #31
Tyso_Bl
Tyso_Bl's Avatar
Here is one I made earlier, (about 20 years ago), good to 2M blow a fan over it when QRO!
ID:	210370   Click image for larger version
Adapt, Improvise, Oh Bother.....
Tyso_Bl is offline
