15th Oct 2017, 11:13 pm | #61 |
Re: Modern soldering stations.
That will most likely be a shorted thermostat.
16th Oct 2017, 12:17 am | #62 |
I took the tip off cleaned it up and reinserted and it's now not glowing a dull red?
Could it be a duff tip or as you say the stat.? I still cannot hear any clicking when at operating temp?? Cheers. |
16th Oct 2017, 12:25 am | #63 |
If you measure it with a meter and remove the tip it should change to open circuit.
When it gets up to temperature the thermostat should open. The but of the tip is made of a material that becomes non magnetic when it is heated so that the magnet lets go and allows the switch to open. I have seen switches that are jammed solid so that they are a write off. I have seen new switches on sale at places like Farnell. |
16th Oct 2017, 3:29 pm | #64 |
Is the switch the yellow piece with a capacitor attached to it. I can't see a way of dismantling the switch it has black end caps an I correct??
Cheers. |
16th Oct 2017, 4:02 pm | #65 |
That sounds like the switch in a TCP iron. It has a long shaft that goes up inside the element. Inside the shaft is the magnet that is attracted to the back of the bit.
The yellow part is actually sticky tape I think. You can peel it off (or you could on the ones I've worked on) and remove the cover from the switch (this cover is a rectangle with semicircular ends if you see what I mean, and is black in colour). Do check that the capacitor (wired in parallel with the switch) is not shorted too. A replacement switch from Weller comes with the capacitor and 2 short wires to connect to the tags on the frame inside the iron. |
16th Oct 2017, 4:08 pm | #66 |
Many thanks Tony. Just bought the iron should have checked beforehand that switch was ok really but there we go,I don't think seller knew how they worked anyhow as I asked about whether it clicked during operation and he didn't have a clue what I was on about or maybe he was acting dumb??
With the price of a switch I'm not sure if it was such a good buyat £30, but there we go eh?? Cheers. |
16th Oct 2017, 4:40 pm | #67 |
You're still doing alright.
You will have to check it's the right part before obtaining it but there are switches (PN 51020199) on ebay for £27.06 including delivery which is reasonable. If you end up spending less than £80 in total you're still up on a guaranteed working one and the switch certainly won't jam or die in the near future! |
16th Oct 2017, 10:30 pm | #68 |
If you unscrew the barrel and move the tip in and out of the element and you can hear it clicking it will be the capacitor.
17th Oct 2017, 12:06 am | #69 |
Hi, took the iron apart and cleaned the switch contacts and put back together. Worked ok for a bit could hear the switch operating very quietly, but after a while of soldering the iron sticks open and won't heat up intermittently without tapping the iron
I noticed that one section of the switch has a very small diameter piece of wire that provides into the heating element,mine was about 20mm long and very rusty is this how.it should be?? With regard to the capacitor does this need to be removed to test it? Thanks |
17th Oct 2017, 12:47 am | #70 |
I would clean the switch and the wire perhaps with water. You need to get all the dust out of the switch otherwise it will keep sticking. Dry it on a central heating radiator for a few hours before trying it again.
The switch cover needs to be put back accurately ot this will also cause to to stick again. The capacitor can be tested with the tip removed but it is most likely to be fine now you have got some life out of the switch. |
17th Oct 2017, 10:44 am | #71 |
Mine doesn't audibly click in operation but as has been noted you can feel/hear it when moving the bit in and out.
Gordon |
17th Oct 2017, 11:12 am | #72 |
I bashed mine on the table a few times and it has unstuck!
I'm slightly tempted to buy a Hakko one just to see. |
17th Oct 2017, 1:57 pm | #73 |
Wow, one of the new weller soldering stations has a password lock !
Just what I need dc |
17th Oct 2017, 2:32 pm | #74 |
I can see my RMA now "forgotten password"
4th Mar 2018, 12:17 pm | #75 | |
The truth is it isn't a temperature controlled iron and Lidl don't claim that it is. I haven't dismantled it, but I am convinced that it is a variable power iron with the power input controlled by a triac circuit similar to that used in incandescent lamp dimmers. A transistor radio placed near the station gives away a tell tail buzz that varies with adjustment of the control knob. |
