Reply
Old 21st Nov 2023, 3:56 pm   #1
hugocarmo
Default Mitsubishi HS-E82 VCR Bad Picture
Good morning everyone.
This time I have a Mitsubishi HS-E82.
It was a bargain that I found with original remote included.
The problem reported by the owner is that it was working but no output video.
I took it appart and immediately saw that three 470uf capacitors were leaking on the signal board and one in the Hi-Fi board the same value too. I have located them in the pictures in red marker.
I replaced them, cleaned all the liquid remains and the video output got working again.
I saw too that were three surface mounted capacitors, two near the 470uf and one in a vertical board. I replaced them too, they were leaking too.
I replaced one surface mounted capacitor in the drum motor pcb, it was leaking too.
Now, resuming.
I have video output, vcr menu and tv channels with good picture, if I attach RCA cables to audio input AUX, and a bluetooth receiver I have good Stereo Sound, but no stereo in tv channels nor tape playback. I have the problem you can see in the video that I´ve attached.
I cleaned the upper drum heads, with printer paper and IPA, like I do to my other VCR´s, no luck.
Is this bad worn heads symptoms? Or I need to investigate deeper in the pcb´s for more bad caps?
Thank You!
Hugo.
Video link
https://vimeo.com/886789022
ID:	288523   Click image for larger version
ID:	288524   Click image for larger version
ID:	288525   Click image for larger version
ID:	288526   Click image for larger version
hugocarmo is offline   Reply With Quote
Old 22nd Nov 2023, 8:52 am   #2
whaka54
Default Re: Mitsubishi HS-E82 VCR Bad Picture
hello,
not bad heads, but tape transport definitely looks misaligned.
and i highly suspect someone messed the tape guides when video was wrong.
so you'll have to reajust them and i'm sure you'll get it back
whaka54 is offline   Reply With Quote
Old 22nd Nov 2023, 10:52 am   #3
hugocarmo
Originally Posted by whaka54 View Post
hello,
Hi whaka54.
You´re right!
The tape guides are messed up, maybe by the last owner.
I´m trying to fine tune them, I have a much better picture now, but it needs more tuning!!
Thank You!!
Old 22nd Nov 2023, 11:16 pm   #4
John123
Don't neglect the PSU, as any bad capacitors in there may cause the machine to behave erratically. Given its age, I would highly recommend you replace all capacitors in the PSU, minus perhaps the main reservoir cap (in the primary), as these rarely go bad (safely discharge and check ESR anyway).
As always, caution advised when dealing with incoming mains and the potential of stored high-voltage DC.
Regards,
John
John123 is offline   Reply With Quote
Old 23rd Nov 2023, 12:09 am   #5
hugocarmo
Thank You for your answer.
I already did, that’s always the first thing I do when repairing old devices.
I recap all the PSU everytime!
Old 23rd Nov 2023, 8:07 pm   #6
John123
Excellent! It's definitely good practice with things like this
Regards,
John
Old 24th Nov 2023, 2:16 pm   #7
dj_fivos_sak
Congrats. That's a nice S-VHS machine from the era when build quality was still in manufacturer's minds. The trick to adjust the tape path alignment without an oscilloscope is to use a Hi-Fi tape recorded in the LP speed on a known-good machine and perform the adjustment until the Hi-Fi audio is clear without any 50Hz buzzing noise with the tracking control in the center or reset position. Although the picture might be clear, the hi-fi audio is much more sensitive to tracking errors and there's very little room for errors, especially in LP. Then confirm tape interchangability by playing back a tape recorded on the HS-E82 in LP on another machine.
dj_fivos_sak is offline   Reply With Quote
Reply
