Reply
Old 30th Sep 2023, 3:14 pm   #1
FERNSEH
FERNSEH's Avatar
Default Rectifier diode with three pins.
Yesterday, I found this unusual valve. There's evidence it was made by Tungsram but I can't find the valve's type number.
Essentially a full wave rectifier having both sections wired in parallel.
This three pin valve will fit in a standard B4 socket.
DFWB.
ID:	285788   Click image for larger version
FERNSEH is offline   Reply With Quote
Old 30th Sep 2023, 6:11 pm   #2
kalee20
Default Re: Rectifier diode with three pins.
Wow!
I've never seen anything like that before...
kalee20 is offline   Reply With Quote
Old 30th Sep 2023, 6:53 pm   #3
Silicon
Is there a logo embossed or printed on the valve base?
B4 bases with only 3 pins were sometimes used for mercury vapour rectifiers (i.e. GU1).
However their internal structure is very different.
Silicon is offline   Reply With Quote
Old 30th Sep 2023, 7:51 pm   #4
ms660
ms660's Avatar
Tungsram V4200:
https://www.radiomuseum.org/tubes/tube_v4200.html
Lawrence
ms660 is offline   Reply With Quote
Old 1st Oct 2023, 11:59 am   #5
Chrispy57
Hi - certainly unusual, but you may need to reconsider this statement "Essentially a full wave rectifier having both sections wired in parallel."
Chris
Chrispy57 is offline   Reply With Quote
Old 1st Oct 2023, 2:06 pm   #6
ms660
ms660's Avatar
The Tungsram V4200 specs. are Vh 4V, Ih 2A, VAC max. 800V, I max. 120mA.
Lawrence.
Old 1st Oct 2023, 4:16 pm   #7
60136 Alcazar
60136 Alcazar's Avatar
The Tungsram V495 from 1930 (400V/70mA directly heated 4 volt/1 amp) also had 3 pins and two anode structures. In fact Tungsram seems to have been fond of this arrangement as the APP4D was a single envelope containing two APP4A electrode structures strapped together, likewise the PP4018 was two PP2018 structures.
John
Progress consists of doing what you've always done - just more expensively.
60136 Alcazar is offline   Reply With Quote
Old 1st Oct 2023, 5:23 pm   #8
Maarten
Maybe they used this arrangement to obtain a higher current capability?
I'd say it is a bit ambiguous, but one of the ways it can be read seems to be correct, or am I missing something?
Maarten is offline   Reply With Quote
Old 1st Oct 2023, 11:13 pm   #9
Chrispy57
Hi Maarten,
if it is indeed a V4200, as identified by Lawrence, the three pins are for an anode and both ends of the directly heated cathode, and it is described as a half-wave rectifier in the data sheet available here;- https://www.radiomuseum.org/tubes/tube_v4200.html
There is also the PV4200, which is a full wave rectifier having two anodes and a directly heated cathode, but this has 4 pins, data sheet here;- https://www.radiomuseum.org/tubes/tube_pv4200.html
Chris
Old 2nd Oct 2023, 10:30 am   #10
60136 Alcazar
The Tungsram arrangement used two electrode structures and two filaments/electron streams, but internally strapped anodes (and grids/cathodes as appropriate) and filaments internally connected in parallel (or in series for AC/DC types). And yes, this was to cater for an increased Ia rating. In the V4200 case, two anodes internally strapped together only need one external base pin connection, plus the two filament pins (with the two separate filaments paralleled within the envelope). So it is basically a twin diode internally configured as a half-wave rectifier.
John
Old 4th Oct 2023, 2:57 am   #11
Oldmadham
Three pins for a full wave rectifier wouldn't work, as the filament needs two pins to function.
Oldmadham is offline   Reply With Quote
Old 4th Oct 2023, 9:45 pm   #12
Herald1360
Herald1360's Avatar
Don't forget the 0Z4
OK so it actually has 5 pins fitted to its octal base but only three of them are active!
It's also rather noisy RF wise, as I found out the hard way in a home brew PSU for a R1155
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline   Reply With Quote
Old 5th Oct 2023, 10:24 pm   #13
FERNSEH
FERNSEH's Avatar
Introduced in the mid 1950s, except for it's heater voltage. the EY84 has similar characteristics as the V4200.
From the Radiomuseum: https://www.radiomuseum.org/tubes/tube_ey84.html
Slightly different, the Brimar R18.
https://www.radiomuseum.org/tubes/tube_r18_brimar.html
DFWB.
Old 21st Nov 2023, 11:00 am   #14
Station X
Station X's Avatar
One post moved to a new thread here:-
https://www.vintage-radio.net/forum/...d.php?t=205696
Graham. Forum Moderator
Station X is offline   Reply With Quote
Old 24th Nov 2023, 2:12 am   #15
Oldmadham
DFWB.
As the heater/filament needs two pins to work, you only have one pin left, so, at least functionally, it is a half wave rectifier using a directly heated cathode.
The valve manufacturer may be doing some "smart stuff" internally & reusing an already available stock structure from a full wave rectifier, but to the outside world it is a half wave rectifier.
Reply
