Television Standards Converters, Modulators etc Standards converters, modulators anything else for providing signals to vintage televisions. |
6th Oct 2010, 12:00 am | #1 |
Professional 625 -> 405 Convertor
Apologies if this has been posted elsewhere or isn't in the right section of the forum, but I thought you might be interested in this video of a very interesting piece of kit
http://www.youtube.com/watch?v=RJVCA2OvQng Paul |
6th Oct 2010, 12:34 am | #2 |
Re: Professional 625 -> 405 Convertor
So someone actually got one of those to work! My God....
Cheers, Steve P.
6th Oct 2010, 7:40 am | #3 |
That's the one that belongs to Malcolm Everiss. Getting one of those to work, with its thousands of electrolytics, slightly iffy germanium diodes etc is a mammoth effort. The resistors should mostly be OK. Those chunky looking parts are high stability types, rated at 0.25W I think, and mostly run well within this. The OC140, used in huge numbers here, is a very special transistor. It is symmetrical, the collector and emitter can be interchanged. This makes it ideal as a signal switch. There is no modern equivalent.
Malcolm is also known for the "Domino" 625>405 converter which was the defacto standard until the Aurora arrived. http://www.domino405.co.uk/ |
6th Oct 2010, 10:01 am | #4 |
Phew, is it hot in here or is it just me?
Is this type of video legal? It's like a dirty movie for standards converter fetishists. I'm off for a cold shower. Wonderful stuff. Parabola |
6th Oct 2010, 10:18 am | #5 |
A couple of pages from the CO6/501 manual. I have a photocopy of the entire manual. It's about 2" thick. Serious hardcore stuff.
Parabola, since you're local it's available on loan |
6th Oct 2010, 11:19 am | #6 |
I'm still not sure what I am going to do with this converter. (Pictured) It has not been in use for a long time and is now full of faults which will take some time to sort out. It was constructed late 1989 as a replacement for an earlier converter which was constructed in 1984/5.
The first converter is still in use by a member of this forum. I use two Auroras now, the first multi-standard version and NTSC405 multi channel unit. Bought to operate with the Pye 405CTV. DFWB. |
6th Oct 2010, 11:34 am | #7 |
Re Malcolms standards converter,went over to Scarborough years ago in a hired van to pick same up only to find the guy had changed his mind about parting with it!
David |
6th Oct 2010, 11:47 am | #8 |
Way back in the late eighties I had a Pye standards converter. It was later passed on to another collector in the South of England.
The reason for not keeping it was that the TV and video trade was booming and there no time available to restore such a mighty piece of equipment. I wonder where that converter is now? |
6th Oct 2010, 11:59 am | #9 |
Fernseh (David Boynes) designed and built the first 625>405 converter other than those designed by the BBC. It predated the Dinosaur, Pineapple and David Looser's designs by several years. It was a substantial achievement to do this with the parts available at the time, espeically as David is not a professional design engineer.
6th Oct 2010, 3:05 pm | #10 |
And i remember reading all the updates on that convertor by Fernseh in 405 Alive.Oh, the years go by!
David |
6th Oct 2010, 4:39 pm | #11 |
Of course RTE had the ultimate professional standards converter once their own one chucked it! It was a 405 line camera set up to "see" a picture off a 625 line set!
6th Oct 2010, 4:52 pm | #12 | |
Field rate conversion was a much tougher nut to crack. Optical conversion reigned supreme until the BBC built their first analogue field rate converter in time for the 1968 Mexico Olympics. |
6th Oct 2010, 5:31 pm | #13 |
Just goes to show what an amazing piece of kit an aurora is
Mark |
6th Oct 2010, 5:57 pm | #14 |
Too right Mark, every time I have my sets on I really can not comprehend what Darryl has designed and produced, a totally amazing feat.
6th Oct 2010, 8:11 pm | #15 |
Totally agree! It is so perfect that I sometimes think 405 is still being transmitted!
The amazing thing is I cannot remember the converted 405 line signal provided by one of these Goliath units breaking down. The picture was slightly 'different' to the original live signal but of excellent quality and served us very well. Simply amazing bit of kit. Regards, John. |
6th Oct 2010, 8:16 pm | #16 |
Towards the end of 405 TX the maintenance on the converters was, shall we say, a bit negelected. This would have been less serious on BBC1 where the later digital CO6/509 was a pretty reliable machine. It was designed specifically because the the BBC thought that the 405 service would outlast the reasonable service life of the CO6/501. ITV soldiered on with Pye built CO6/501 all the way to the end.
PS: I suspect the converters at Crystal Palace and Croydon would have received better attention than most others. The usual London effect. |
6th Oct 2010, 8:36 pm | #17 |
The pictures on 405 lines BBC1 from Kirk O' Shotts on Ch3 & STV from Blackhill on Ch10 were always spot on even in the last few months of 405.
I lost some interest in vintage radio & TV about that time but had seen 405 a few times before the closure and it was always good.
8th Oct 2010, 9:13 am | #18 | |
What you may not appreciate was, that at any given station, there'd be two of the things running in parallel, with a bloke constantly on hand to switch from one to the other if the 'service' unit started to display eccentric tendencies, which they certainly did on a weekly basis and sometimes daily. In bad periods, it could be a struggle to keep even one of the units in good working fettle. However, with a mixture of experience and deep cunning the service was usually maintained to an acceptable standard. Also, bear in mind that you'd be viewing the end results on a domestic telly, as like as not: we were looking at the goods using professional studio monitors (Pye 2780 actually) which gave superb pictures upon which any defects were screamingly obvious... |
8th Oct 2010, 9:26 am | #19 | |
8th Oct 2010, 10:10 am | #20 | |
polystyrene capacitors, and there was far too much going on at that time to sort out the foibles of a new bit of tackle that'd likely not be needed (I recall that when we did try our specimen of 509, we found that it wasn't entirely without defects itself...) |
