Old 22nd Feb 2024, 10:05 pm   #1
Michael Maurice
Michael Maurice's Avatar
Default Revox A77, potentiometers
I’m referring to the input level, balance and volume controls.
These are no longer available from the manufacturer and they are totally non standard.
Someone is selling an ALPS version on eBay but at just over £85 it is very expensive.
Apart from a second hand one if you can find one, has anyone any ideas as to how to get around the problem?
Forum Moderator
Michael Maurice is offline   Reply With Quote
Old 23rd Feb 2024, 11:17 am   #2
Welsh Anorak
Welsh Anorak's Avatar
Default Re: Revox A77, potentiometers
Hi Michael
I have a VERY scrap A77 here. I've removed the controls. They all have slightly bent shafts and one of the input level controls has seized solid, but they're yours if you need them.
Glyn
www.gdelectronics.wales
Welsh Anorak is offline   Reply With Quote
Old 23rd Feb 2024, 1:12 pm   #3
Michael Maurice
Originally Posted by Welsh Anorak View Post
Hi Michael
Yes please
Forum Moderator
Old 23rd Feb 2024, 3:47 pm   #4
Welsh Anorak
PM sent.
Glyn
Old 23rd Feb 2024, 6:35 pm   #5
Uncle Bulgaria
Uncle Bulgaria's Avatar
It seems the usual suggestion for anything potentiometer related is to talk to Blore Edwards. I imagine you have long experience with the machines, so if these things are commonly wanted perhaps even getting a minimum order manufactured would be worthwhile? What do the Revox spares firms do?
Uncle Bulgaria is offline   Reply With Quote
Old 23rd Feb 2024, 8:28 pm   #6
Michael Maurice
I've tried Blore Edwards, they don't have anything suitable, I may explore a method using Piher potentiometers, make up brackets, a coupler, a suitable shaft and a PCB.
I would prefer to use a 16mm pot rather than the usual 24mm. Space is quite limited.
Forum Moderator
Old 24th Feb 2024, 1:27 am   #7
TIMTAPE
Michael what are the problems with the pots you are encountering?
TIMTAPE is offline   Reply With Quote
Old 24th Feb 2024, 11:14 am   #8
Michael Maurice
Very intermittent contact on CH2, not curable with switch cleaner. mainly no go as though the contact on the slider has failed.
I haven't opened it up, this is a professional repair for a customer.
Forum Moderator
Old 24th Feb 2024, 1:25 pm   #9
Draker4c
Nagravox?…..
Draker4c is offline   Reply With Quote
Old 24th Feb 2024, 2:14 pm   #10
TIMTAPE
On some cases of badly tarnished contacts I find the spray switch cleaner I use evaporates too quickly to do much. I sometimes soak a tarnished part in a mildly acidic bath like vinegar for a few hours. If the problem cant be fixed any other way, there's nothing to lose.
I did this recently on the long B77 speed and EQ change switch. The many contacts had tarnished badly apparently due to a combination of much accumulated dust and moisture. The contacts came up well.
Old 26th Feb 2024, 5:29 pm   #11
Uncle Bulgaria
I guessed you'd probably already been in touch with B.E. Are they not able to make ones to spec? Perhaps they're too peculiar in casing or construction to be able to copy on their machinery.
Old 27th Feb 2024, 10:03 pm   #12
Michael Maurice
The only ones they can do is AR45 24mm ones, not 16mm. I would have to get brackets made up anyway but the 24mm ones are quite large compared with the originals. I made enquire from Piher.
Forum Moderator
Old 27th Feb 2024, 10:16 pm   #13
vidjoman
Are these pots the type with a diecast metal case held together with small rivets? I ask because many years ago I replaced the carbon track with the track taken from a preset. The rivets were carefully drilled just enough to be able to punch them out and they were reused with a tiny amount of araldite to keep them in place. It was on a tape recorder and had a long shaft but I don’t remember which type, although it wasn’t a Revox.
vidjoman is offline   Reply With Quote
Old 27th Feb 2024, 10:18 pm   #14
Michael Maurice
Interesting, yes the are this type, I’ll have a try at doing this, though I’ve now got a replacement pot.
Forum Moderator
