10th Aug 2020, 6:33 pm | #1 |
Location: Yorkshire Wolds, East Riding of Yorkshire, UK.
Cyrus PSX (for the Cyrus 2)
A recent underrated fuse (3A) which should have been 5A, has made me consider whether I should change the large electrolytic capacitors in this power supply.
Thoughts, if so what make and models, and where to obtain them ? |
13th Aug 2020, 7:44 pm | #2 |
Re: Cyrus PSX (for the Cyrus 2)
any comments ?
13th Aug 2020, 10:31 pm | #3 |
Some background to your question can be found here: https://www.diyaudio.com/forums/soli...ains-plug.html
It looks like you are concerned about the state of the capacitors because the power supply was running with a 3A instead of 5A fuse in the mains plug. I don't see how this can harm the capacitors in any way.
Robert |
13th Aug 2020, 11:25 pm | #4 |
You're deducing that the main reservoirs have gone high ESR because they couldn't muster enough surge current on turn-on to pop the under size fuse?
A fuse should blow at the rated current, taking 1000 hours to do so. Run them a bit lower and the time goes up somewhat slowly at first. THey are not precision knife-edge devices. Only in Hollywood thrillers. David
