Reply
Old 20th Oct 2017, 8:29 am   #1
Edwar65
Default Garrard 301
Hi, can anyone advise as to what's involved in removing the arm assembly from this turntable. A friend of mine has sold the deck, but the buyer does not want the arm or plinth, hence he's asked me to remove it before it's shipped. If anyone can offer some helpful if be most greatful.
Thanks.
Edwar65 is offline   Reply With Quote
Old 20th Oct 2017, 8:35 am   #2
vidjoman
Default Re: Garrard 301
The arm is fitted to the plinth not the 301.
vidjoman is offline   Reply With Quote
Old 20th Oct 2017, 8:35 am   #3
lesmw0sec
I'm a bit confused here - surely the arm is not a part of the turntable? In which case it would be a simple matter of around 4 screws and disconnecting the wiring. The 301 as I recall, is just fitted on to the plinth with four bolts.
lesmw0sec is offline   Reply With Quote
Old 20th Oct 2017, 9:49 am   #4
alanworland
alanworland's Avatar
Sounds like you need to remove the deck from the plinth.
Alan
alanworland is offline   Reply With Quote
Old 20th Oct 2017, 10:30 am   #5
ukcol
ukcol's Avatar
The manual for the Garrard 301 is available here:
https://www.manualslib.com/manual/10...rrard-301.html
It contains instructions for mounting the turntable on a plinth. Simply follow those instructions in reverse order to remove the turntable. This will leave the turntable separated from the plinth and arm.
Best Regards, Colin McLaughlin
BVWS Member
ukcol is offline   Reply With Quote
Old 20th Oct 2017, 10:55 am   #6
Nickthedentist
Nickthedentist's Avatar
Note that you MUST remove the platter and pack it safely before you ship it. There may also be other precautions people here can advise you about. These are worth a lot these days so it pays to be very diligent!
Nick.
Nickthedentist is offline   Reply With Quote
Old 20th Oct 2017, 12:36 pm   #7
barretter
Yes, there's also a transit bolt that needs to be tightened up.
barretter is offline   Reply With Quote
Old 20th Oct 2017, 10:43 pm   #8
Edwar65
Ok thanks for all the help, will take a a look as soon as, a great resource as always and very friendly folk too!!
Old 21st Oct 2017, 3:33 am   #9
GP49000
TWO of them, on the motor mounting frame.
GP49000 is offline   Reply With Quote
Old 21st Oct 2017, 8:03 am   #10
barretter
Quite right, and they're usually painted red. To remove the platter you need to exert upward pressure on it while gently tapping the spindle with a rubber hammer or something similar, otherwise you will pull the spindle out along with the platter.
Reply
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright ©2002 - 2017, Paul Stenning.
