5th May 2016, 11:22 am | #1 |
Signal Generator HP200
I'm wondering, was the HP200 (any variant of) made to suit 240V mains? Obviously the early models were built by a couple of guys in a garage, for American 110V power, but I'd rather like one and living in Britain, it would be nice not to have to ether use a step down transformer, or rewind the original! Not to say that avoidable modification of Hewlett-Packard original work would be sacrilegious anyway!
5th May 2016, 1:24 pm | #2 |
Re: Signal Generator HP200
HP 200C and 200D were later versions pretty much the original circuit but miniature valves. 110 and 240v selectors were standard. But in a newer style case, I'm afraid. Still Bill's bulb.
I bought one for £15 about 15 years ago and stood it in the lobby of the Queensferry microwave division. Don't know where it got to. It was only on loan from me, but I've left and the buildings are all demolished. David
5th May 2016, 5:43 pm | #3 |
I have quite a large collection to HP test equipment from the late 1950's to 1970's, all of mine have either solder links on the mains transformer, or a slide switch for changing between 110V or 240V operation.
David |
5th May 2016, 5:59 pm | #4 |
The 200A was certainly kept on the catalogue for a long time and there are examples in Europe, so they must be 220-240v capable.
The 200A is a nice bit of history. I once came back from lunch to my desk to find the designer of it sitting on my work bench, swinging his legs and looking at a breadboard I was building. David
5th May 2016, 7:22 pm | #5 |
The manuals for both early and later HP 200 audio oscillators can be found on the HP archive website here: http://www.hparchive.com/hp_equipment.htm
The manuals for the single letter variants only mention 110V operation, including the circuit diagram & parts lists. I would be surprised if there aren't 230V versions though. The earliest mains powered item in my HP collection is the 500A, it can run from both 110V or 230V, with a tag strip for changing voltage. Its always worth checking HP equipment is set for the correct voltage, even if it was bought in the UK, I've had a few UK bought ones set for 110V. David |
5th May 2016, 11:20 pm | #6 |
Thanks folks, I'll keep looking then.
Wow! You HAVE moved in exalted circles! |
5th May 2016, 11:49 pm | #7 |
Not really
6th May 2016, 12:22 am | #8 |
I went over the editing time limit...
Not really. They were good engineers and good human beings. What was special was that even confronted with success and wealth, they kept those values. They kept abreast of technologies and could see through flim-flam. There were a couple of tales floating around the lab of people who'd tried bullshitting an answer to a technical question. They made it absolutely clear that it was their lab and that they could wander around it and chat to people without the presence of hierarchical management. You had a nice engineer-to-engineer natter without an audience. They created a culture where all levels were expected to wander around, know everyone else and what was going on. The very antithesis of the mushroom culture. Everyone in the place met them from time to time, and they took an interest in everyone and everything. David
