Old 13th Jun 2005, 9:26 am   #1
Colin
Colin's Avatar
Default 25k Wirewound pot for CT160 Grid Volts fix
Hi folks,
Can anyone help out with a source of wirewound pots?
I'm in the process of sorting my CT160 and the 'Phelan Phix' (see recent thread on this forum) seems to be the order of the day.
I need a 20k to 25k wirewound pot with a minimum rotation of 270 degrees to replace the 'smoked' Grid Volts pot in the instrument.
If anyone has one of these in the spares box, or knows where I can go to source one, I'd be very pleased to hear from you.
Thanks and best regards
Colin
Colin is offline
Old 13th Jun 2005, 8:08 pm   #2
Colin
Colin's Avatar
Default Re: 25k Wirewound pot for CT160 Grid Volts fix
Thanks Graham,
I know about the pot and its unique properties and I followed Mike's repair with interest. I needed a pot to modify in the same way Mike did so I can replace the original in mine.
Colin
Colin is offline
Old 13th Jun 2005, 10:10 pm   #3
Station X
Station X's Avatar
Colin.
I should have read your post properly before replying.
Farnell stock a good range of wirewound pots in the values you specify. I prefer the Colvern types myself, but don't know how easy or difficult they are to modify.
www.farnell.co.uk
Graham.
Station X is online now
Old 17th Jun 2005, 12:01 pm   #4
Colin
Colin's Avatar
Just to finish off this thread. I sourced a new Colvern 25k pot from Farnell (thanks for pointing me in their direction Graham) and have now completed the repair. The CT160 is working fine and well within calibration limits. I'd also like to thank Mike for his help and advice.
I've posted a few pics of the repair for those of you who may be interested.
Regards
Colin
ID:	859   Click image for larger version
Name:	CT160 Grid Volts Pot replacement unit.JPG
ID:	860   Click image for larger version
Name:	CT160 Grid Volts Pot replacement.JPG
ID:	861   Click image for larger version
Name:	CT160 replacement GV pot in situ.JPG
ID:	862   Click image for larger version
Name:	CT160 replacement GV pot in situ 1.JPG
Colin is offline
