27th Aug 2019, 10:30 am | #1 |
Radio Identification 60s/70s Transistor Radio (Ferranti PT1030)
Hi, My grandad passed away recently after 100 happy years and the family have been sorting through his belongings. One of the items that caught my eye was this old transistor radio that I remember from my youth. He'd kept it after all these years and I (foolishly?) offered to restore it or at the very least make it work.
Unfortunately, there are absolutely no markings anywhere on the case that I can see. It's in poor condition; the worms have been at it (and look like they may still be at it) and the dial markings are literally peeling away. I'll be happy just to halt its decline to be honest. Does anyone recognize the brand/model? It looks like a Bush with the metal band across the front and the metal grill. But I can't find an exact match. Also, I bought some permethrin in the form of ant killer treatment and I was planning to mix this with water and dunk the case into it. I'm not sure that's the right thing to do? Any suggestions? |
27th Aug 2019, 10:41 am | #2 |
Re: Radio Identification 60s/70s Transistor Radio
It looks a bit to me like a 'Stella' a Philips offshoot, can't be sure though.
Peter |
27th Aug 2019, 10:54 am | #3 |
It may be a special for the Irish market. Both Pye and Philips had significant manufacturing operations in the Republic and did produce unique models tailored to Irish conditions. You may find some manufacturer info inside the battery compartment or on the circuit board.
It's unlikely to be a very complex set internally, though it may use the dreaded AF117 transistors. Search the forum for lots of threads about those. You can get rid of any active woodworm by putting the radio in a freezer for a couple of days, though this doesn't always kill all the eggs. You can buy purpose designed woodworm killer which poisons the wood. There are lots of threads about woodworm if you search. |
27th Aug 2019, 10:57 am | #4 |
looks much like a Ekco BPT351
27th Aug 2019, 10:59 am | #5 |
Well spotted: https://www.radiomuseum.org/r/ekco_bpt351bpt_35.html
27th Aug 2019, 11:17 am | #6 |
Fixit, you're a star! That's why I love this site. I'm not even going to ask how you managed to spot the model so fast.
@Paul, you're right Pye, Bush and Philips were very popular in the west of Ireland back in the day and I looked at those brands first. Great to have a schematic! By the way, what's the best way to salvage that peeling dial print. Obviously, what's gone is gone, but could you coat what's left in some kind of fixative to halt the peeling or is it beyond redemption? |
27th Aug 2019, 11:56 am | #7 |
got one in Red, I had to ask here as mine was also missing the Ekco Label as yours is but mine has a plastic grill where yours has a metal one
also came as Ferranti PT1030 |
27th Aug 2019, 12:01 pm | #8 |
The best approach is usually to remove the dial glass and scan it with a scanner. You can then use photo editing software to repair damage and replace missing text. Then print out the image using paper, transparent plastic or waterslide transfer material as appropriate. People have achieved amazing results with this method.
If you're very lucky you may be able to find a scan of an intact scale on the net somewhere. |
27th Aug 2019, 12:35 pm | #9 |
The inverted scale allows the set to be used in a car in the glove box - there is a car
aerial socket. You may find back lighting the dial during the scan improves matters. |
27th Aug 2019, 12:39 pm | #10 |
Looks like the old man was a smoker! I guess those burns are part of the set's history though, rather than something to try to restore.
Other than dried out electrolytics and dirty switch contacts I would expect it to work more or less as it is. There's no AF11x nasties to worry about, the earlier OC series are generally pretty reliable.
27th Aug 2019, 12:49 pm | #11 |
I would scan it first just in case then try a very fine mist coat of clear lacquer (from say half a meter away so as not to blow about what's loose) With this over what's left of the dial ,then let it dry and if ok more mist coats if lucky it will not run and a few coats should hold the rest in place
27th Aug 2019, 2:02 pm | #12 |
That's a clever approach Paul. Looks like I need to decide whether to replace or fix(ate). I'm guessing Fixit's lacquer treatment would make replacement difficult at a later date.
Herald, he was a smoker in his youth in common with men of his generation. But he quit many years ago, which probably explains his longevity. His weakness was the odd fried breakfast (the morning after a feed of beer) and I wonder if the top of that radio formed a nice perch for a hot egg flip or poker. |
27th Aug 2019, 2:08 pm | #13 |
It's a Ferranti PT 1030 I have had one of these since the early 60s .
It's described in the 'red books' series r&tv servicing 1960-61. page 122. mine just about still works but the dial is peeling just like yours. I seem to remember paying fifty bob, £2.50 for it second hand. I had started working as a 'sparks' then and another guy wanted a few quid to go to the dogs at White city Manchester. it's the first transistor radio I owned first of many many more, the things seem to breed.
HAPPINESS IS A WARM WIRELESS PREVIOUS USER NAME- MIKE G3ZII |
27th Aug 2019, 3:20 pm | #14 |
I never thought I'd get old enough to have trouble identifying transistor radios but this one got me. I know most of the Perdio, Bush and Ferranti range with the Band Spread and trawler bands. Perhaps dementia enhances and wakes up times of years ago. Then again I must realise we are of differing ages, I see people that dont even recognise a VHS tape cassette. But what a radio, does it run?
27th Aug 2019, 6:40 pm | #15 |
You guys know an awful lot more than I do and for that I'm grateful. Now,...time to get the worms out!
28th Aug 2019, 4:43 pm | #16 | |
Yes I have had my PT1030 for some years now, and I had the same identification problem. Similarly, some kind person on this Forum identified mine too! Mine's not in bad condition, - just a bit grubby, but I haven't used it in a long time,- must fire it up again. Kind regards Dave G0ELJ |
