Old 9th Oct 2018, 8:48 pm   #41
volte-face
Default Re: Dynatron CTV63 problem
Just to, hopefully, help clarify this clamp business for you, please see the attached pictures.
The clamp screw is actually hidden behind the four pole unit and accessible via a slot in approx the 1 o'clock position.
Please do take note of all the previous warnings regarding the dangers to a novice in all this.
ID:	170644   Click image for larger version
ID:	170645   Click image for larger version
volte-face is offline   Reply With Quote
Old 10th Oct 2018, 7:41 am   #42
Snarf81
Snarf81's Avatar
Hi.
Thank you for the pictures. I've double checked mine and the clamp is indeed missing.
Thanks again.
Richard.
Snarf81 is offline   Reply With Quote
Old 10th Oct 2018, 8:40 am   #43
volte-face
I think you've been quite unlucky to come across a set with what is designed to be, even when fully slackened, a captive part missing. Quite why anybody would go to the trouble to physically remove it seems to make no sense at all
I hope you can find some local help to get it all lined up properly again.
Old 10th Oct 2018, 9:31 am   #44
toshiba tony
toshiba tony's Avatar
I hope you have gone off the idea of binning it, I'm sure between us all on here we can resolve your issues. I have never seen a Dynatron version, I had a Roberts one. After executing preventative repairs on it, (frame IC, and line output dry joints) it did me well.
toshiba tony is offline   Reply With Quote
Old 10th Oct 2018, 11:20 am   #45
Snarf81
Snarf81's Avatar
I'm going to have to ask on here in the wanted section to find out if anyone in my locality can come over to have a go with it I think.
I also think it might be a teletext model too? In one of the pictures I posted there is a teletext/view data box on one of the pcbs.
Thanks again
Richard.
Old 10th Oct 2018, 1:06 pm   #46
Snarf81
Snarf81's Avatar
I've sorted the green tint out. I must've accidentally knocked the blue control on the end of the tube. That's all sorted.
I've just gotta work out why there's a red and green shadow around images, mostly text.
I've included a picture of what I mean.
Thanks again all for the replies and suggestions.
Richard
Old 10th Oct 2018, 2:10 pm   #47
toshiba tony
Right, it doesn't look like a crt defect, and I'm probably not the person to mention it as I have dementia now, but the G11 used the 20AX system (I seem to remember) and whilst it didn't employ the full convergence that the delta tubes used, it still had the rings around the tube to align the red\green or blue rasters.
Old 10th Oct 2018, 2:17 pm   #48
Snarf81
Snarf81's Avatar
Thank you Tony.
I've downloaded the service manual (Thanks Lawrence), so I'll take another look at the section regarding the adjustment rings.
I also need to adjust the focus as the picture is a bit blurry, very noticeable when programme synopsis info is up on my freeview hd box. I'll need to get someone observant to stand in front of the tv to tell me when I've got the adjustments correct.
Thanks again
Richard.
Old 10th Oct 2018, 2:43 pm   #49
Welsh Anorak
Welsh Anorak's Avatar
Hi
Glad things are looking up. As these sets are now some thirty-odd years old there's probably some history going on there. For some reason it seems the scan coils have been taken off and replaced - could be because another set way in the past had its clamp missing! You'll never know. However, as scan coils like this rarely if ever fail it's very likely you'll get one. Careful adjustment of the rings will get the convergence back, but as mentioned above, you can get a shock doing that if you're not careful - we've all done it! Well, I have...
Remember the first rule of TV - keep one hand in your pocket when one hand is in the set.
It's good to see an old G11 going again, so whatever you do keep it in one piece!
And invest in a mirror!
Glyn
www.gdelectronics.wales
Welsh Anorak is online now   Reply With Quote
Old 10th Oct 2018, 3:17 pm   #50
Maarten
The red and green shadow are a likely convergence issue, also dependent on the position of the yoke and various adjustment rings.
Maarten is offline   Reply With Quote
Old 10th Oct 2018, 4:37 pm   #51
Snarf81
Snarf81's Avatar
Hi Glyn.
Thanks for the reply, yes things are looking up, I've just gotta sort that convergence set up properly but I'm not confident enough to do it so I'll probably leave it as it is until I can find someone in my area who could do it for me.
I do indeed need to get a mirror to shove in front of it so I can see the adjustments on screen. I'll take note again of the electric shock hazard of the live chassis.
I also need to get the focus adjusted and the 'boom' on the picture sorted when a bright image comes up, like a white screen with text etc on it. The whole picture distorts somewhat. There's also an audible boom sound from the speaker when the picture does it. It was like that when I got it. Turning the contrast down a bit helps but doesn't cure it.
Hi Maarten,
Thanks you, I'm going to look in the service manual and read all about those damn rings.
Thanks again
Richard.
Old 10th Oct 2018, 4:50 pm   #52
Snarf81
Snarf81's Avatar
I've just put an ad up in the 'Services wanted' section asking if anyone in my locality could come to mine and set it up.
Richard.
Old 11th Oct 2018, 2:00 pm   #53
MALC SCOTT
MALC SCOTT's Avatar
I would remove the blue LCR cap and check it. The early LCR caps had the same small rivets as the red Pye ones. I still have a couple of NOS blue ones with the small rivets, Malc.
Malc Scott
MALC SCOTT is offline   Reply With Quote
Old 11th Oct 2018, 5:19 pm   #54
Snarf81
Snarf81's Avatar
Hi Malc.
Thanks for the reply. The blue on in my set looks really, really old.
Do you happen to know if replacements are still available to buy?
Thanks
Richard.
Old 11th Oct 2018, 6:01 pm   #55
MALC SCOTT
MALC SCOTT's Avatar
Hi Richard, if it is the correct type with the large rivets, it will be fine. Once it is removed it is easy to tell which type it is. Malc.
Malc Scott
Old 11th Oct 2018, 8:02 pm   #56
Snarf81
Snarf81's Avatar
Hi Malc,
I'm a total crt novice, I wouldn't know if the rivets are large or small without seeing a picture of the differences to compare to mine
Thanks again
Richard.
Old 11th Oct 2018, 8:13 pm   #57
MALC SCOTT
MALC SCOTT's Avatar
Carefully desolder and remove the cap, using solder braid to remove solder. Post a pic here of the connections
Malc Scott
Old 11th Oct 2018, 8:27 pm   #58
Snarf81
Snarf81's Avatar
Ok, thanks.
I'll try to get around to it tomorrow and I'll post a few pictures of it.
Thanks
Richard.
PS. I forgot to say that it has previously been replaced at some point in its history as the solder joints look reworked.
I'll still get it out though, just to be on the safe side.
Old 12th Oct 2018, 1:14 pm   #59
Welsh Anorak
In fact, the later LCR capacitors had WELDED written on the case below the usual markings which is fine. Might save you removing it!
Glyn
Old 12th Oct 2018, 1:37 pm   #60
Snarf81
Snarf81's Avatar
Ok Glyn.
I'll have a look at the pictures I took of it first before I take the back off again.
Thank you.
Richard.
