12th May 2020, 12:17 pm | #1 |
Pye 48A from the grave to life
Living in lockdown I dug out this old 48a I was given as a wreck while having a clear out, no valves, valve bases broken, smoothing cap exploded, no dropper or dial cabinet covered in paint, was just going to scrap it when I thought rather than sitting around I will make it a little project.
Replacing valve bases with B9A using ECH81,(CCH35) EF85,(EF39) EB91, and EL90 (CBL31)Russian 9 pin rewired recapped fitted mains transformer for heaters and whalla one working radio,the loudspeaker was OK, now to find a dial a back and strip the cabinet. John |
12th May 2020, 1:43 pm | #2 |
Re: Pye 48A from the grave to life
Nice title, good work.
12th May 2020, 3:58 pm | #3 |
Nice one! a man after my own heart , hope you find a dial .
12th May 2020, 8:55 pm | #4 |
Well done! It's going to confuse anyone who comes across it in the future trying to match it to the circuit!
13th May 2020, 1:44 pm | #5 |
I have followed pretty much the same design obvious pin outs will be different,
the CBL31/EBL31 replacement using two valves is very simple you just join all the cathodes together eb91 and whatever output valve you have, will put circuit diagram (modified) in the cabinet when finished. Any way it is part of our religion to find faults and make do with what is available, I am quite surprised how well it works though SW is not brilliant. John |
17th May 2020, 3:20 pm | #6 |
If anyone out there has a scan for the dial of this 48A it would be appreciated.
John |
25th May 2020, 6:55 pm | #7 |
Just a follow up, looking at the characteristics of the EBL31 I found the 6CH6 valve was very similar minus the diodes of course, so I thought I would give it a go and replace the EL90 Russian 9 pin for a 6CH6, the radio now has a lot more volume and gain and short wave is not so silent anymore, so if you have a faulty EBL31 it would be easy to make up a little sub chassis with a 6CH6 and EB91 and wire it to a Octal base keeping the radio authentic and working.
John |
25th May 2020, 8:00 pm | #8 | |
Rich. |
26th May 2020, 11:20 am | #9 |
I was wondering just how much output you would get from the EL90 just being driven just by the diode. Given you converted to 6.3V heaters, would not the higher-slope EL84 have been better?
Edward. |
26th May 2020, 1:11 pm | #10 | ||
Have just measured my destroyed glass it measures 19cm wide by 16cm tall so may fit, I will PM you many thanks. John |
26th Sep 2020, 8:56 am | #11 |
Hi Rich thanks for the offer of your dial unfortunately it will not fit as it is part of a cut out in the cabinet,so still looking for a dial or scan, also looking for a
PYE baby QU mains radio, which will take me back to my childhood, all costs met. John |
