3rd May 2020, 11:57 am | #101 |
Re: Wet 1969 ITT-KB junior battery radio
There is a photo of about half of the speaker way back in this thread.
Very little of it was left. Edit Post#5. |
3rd May 2020, 12:32 pm | #102 |
Thanks Refugee, I must have missed that one.
It looks terrible. I wonder if corroded batteries had some influence on this, in that the passivation was erroded and then severe corrosion set in. My little ITT has corrosion on one corner of the speaker due to a cell leaking but obviously caught early. Regards, Symon |
3rd May 2020, 6:37 pm | #103 | |
Regards, Symon |
4th May 2020, 9:04 am | #104 | |
The light is a bit better in the kitchen Last edited by audion_1908; 4th May 2020 at 9:23 am. Reason: Missed text |
4th May 2020, 9:09 am | #105 | |
4th May 2020, 9:23 am | #106 |
Hi.
Under normal circumstances just splaying out the flat screening can solder pins will allow the coil assembly to be pushed out. It seems what's stopping it is corrosion. You could try tapping around the base of the can. Looking at the state of the loudspeaker it's a wonder anything is serviceable. I'd be surprised if those IFTs will be any good, though I think there's a wax coating applied to the windings so who knows. Regards, Symon |
4th May 2020, 9:26 am | #107 |
I've been stepping quietly past this thread for several days now, imagining it would be one of those 'after a quick dry-out and some new batteries...' types.
But I've just read through it and it's a real epic! When I saw those first three pictures I was going to tell you to scrap it and not drive yourself bonkers by even thinking of fixing it! Your patience and tenacity deserve a medal!
Andy G1HBE. |
4th May 2020, 9:27 am | #108 | |
The rust was all over there PCB, I had to excavate the components using a toothbrush, dvm probe and a resistor leg, the military-grade 1% resistors are great but I don't think the original designers would approve of my use of it lol. The IF cans seem to be of a standard size in transistor staff, so could be possible to transplant and new shielding can on to the IF core, Last edited by audion_1908; 4th May 2020 at 9:34 am. |
4th May 2020, 9:34 am | #109 |
Hi.
See pic 1 in post #99. Note the flat screening can pins gently bent outwards. This should help to release the coil assembly. There should be no need to do any cutting of the can. Put the IFT on the bench and give it some decent taps around the sides of the can where it fits the base assembly. Then try gently pushing the coil assembly from the adjustment screw, it should then come out. Regards, Symon |
4th May 2020, 9:43 am | #110 | |
4th May 2020, 9:46 am | #111 |
Its like trying to get corned beef out of a can.
Mike |
4th May 2020, 10:04 am | #112 |
Maybe it's time for us to club together and get audion a replacement, a working example in good cosmetic condition fetches about £8 on ebay. We could desolder everything and supply it as a kit of parts
4th May 2020, 10:16 am | #113 |
Lol no that would be a waste of a good radio, thought would be a lot easier!
4th May 2020, 10:19 am | #114 |
Not quite- there's no way to take a tin opener to the top end so you can push the contents out.
Not sure putting it in the fridge would help either.
4th May 2020, 10:20 am | #115 | |
I can't take a close up pictures with my phone Last edited by audion_1908; 4th May 2020 at 10:27 am. |
4th May 2020, 10:31 am | #116 |
I’ve got to ask, is there any continuity of the speakers voice coil?! If so give it some audio see if it makes a noise!!!
Regards Lloyd |
4th May 2020, 10:31 am | #117 |
Hi.
Good that you finally got it apart. The windings may be OK after all. Regards, Symon |
4th May 2020, 10:38 am | #118 |
Test setup
Tests side with 2 pins 4.7ohm 0.11mH with ferrite on, 4.7ohm 0.08mH without. Tests side with 3 pins outer set 7.5ohm 0.35mH, 0.43mH with ferrite. 5.3ohm 0.10mH center to one side 4.2ohm 0.11mH to the other, both with ferrite It looks like there is a tubular ceramic capacitor in the base, but doesn't seem to show up on the test? The tubular ceramic capacitor appears to be wired across the outer of the three pins on the other side. This seems to show the wires are good, but I don't know how to read the uncalibrated test gear results. I think I'll consider all the other IF can good until proven otherwise as it's likely to destroy the PCB taking them all off! As the copper track has a tendency of coming off the PCB I am waiting for some solder wick to turn up And the ferrite core turns freely! It is a surprise that the cores seems to be ok Last edited by audion_1908; 4th May 2020 at 11:07 am. |
4th May 2020, 10:40 am | #119 | |
Do you want to have a go on the speaker? I will post lol |
4th May 2020, 10:45 am | #120 | |
poppydog |
