Reply
Old 3rd Dec 2023, 5:02 pm   #1
johnmarshmanagain
johnmarshmanagain's Avatar
Default Bush TV63 Narrow Vertical Strip on CRT
Hi again All.
The aforementioned Bush (with lots of cap's done, though not all exact) is only giving me a narrow strip, as you will see.
The cold resistance across points h and j is about 50 ohm, as per the sum of L36 and L37 (as shown), and I cut out C63 as it was suspect s/c.
This may be irrelevant, but the sync sep' transformer (for phase discrim, I think) is o/c, but there are other threads on this subject.
Thoughts welcome
Thanks John
ID:	289167   Click image for larger version
Name:	Screenshot 2023-12-03 3.50.29 PM.jpg
johnmarshmanagain is offline   Reply With Quote
Old 3rd Dec 2023, 5:45 pm   #2
johnmarshmanagain
Default Re: Bush TV63 Narrow Strip on CRT
Update : I turned up the brightness to full, and fiddled with the jumper above R71, and now have more width - albeit with that puzzling bright band effect, as though the line scan sawtooth is not awfully sawtooth ?. Should I invest in a scope ? thanks john
Old 3rd Dec 2023, 5:50 pm   #3
Heatercathodeshort
Heatercathodeshort's Avatar
Looks like incorrect capacitor value, Wrong connection. Very unusual fault for a Bush TV56/66 etc. Was the pic the correct shape before you changed the caps? J.
Heatercathodeshort is offline   Reply With Quote
Old 3rd Dec 2023, 6:07 pm   #4
HamishBoxer
HamishBoxer's Avatar
Possibly caused, as stated by CCCD. Compulsive Capacitor Changing Disorder. Nothing worse than man/woman made fault.
HamishBoxer is online now   Reply With Quote
Old 3rd Dec 2023, 6:22 pm   #5
johnmarshmanagain
Thanks Gents..... CCCD indeed ! I didn't power up until I thought I'd changed any cap that might s/c the HT, or put the LOPT at risk : I'll retrace my steps.
Old 3rd Dec 2023, 6:50 pm   #6
Nanozeugma
Nanozeugma's Avatar
Location: London, UK. Bury, Lancashire quite regularly :)
CCCD. I nearly lost my coffee
Thermionic Emission, warms the cockles of your tubes.
Nanozeugma is online now   Reply With Quote
Old 17th Dec 2023, 1:47 pm   #7
johnmarshmanagain
Thank you for the constructive comments
Old 17th Dec 2023, 8:18 pm   #8
Sideband
Sideband's Avatar
Originally Posted by johnmarshmanagain View Post
Hi again All.
....yes...errr 'though not all exact'.... Well given the preferred values in use today like 0.047uF instead of 0.05uF which won't make one scrap of difference, what do you mean by 'not all exact'? There might be some 'wriggle room' in some parts of the circuit where fitting a 0.22uF in place of a 0.1uF (for example) wouldn't make any difference (like an HT decoupler) but in the line oscillator, sync separator, blanking or the frame scan it will make a lot of difference.
Recheck what you have done.
Sideband is offline   Reply With Quote
Reply
