Reply
Old 22nd Nov 2023, 5:47 pm   #1
Daltonagf
Default Sony SLV T-2000 stops playback after a few seconds
Hi, I have a Sony SLV T-2000, which stops playing after a few seconds (VHS), this is because the counter does not run during playback and winding. Anyone have any ideas how I can solve this? I also had a different video mechanism in it to test, but exactly the same. counter is not running.
Daltonagf is offline   Reply With Quote
Old 22nd Nov 2023, 5:50 pm   #2
Daltonagf
Default Re: Sony SLV T-2000 stops playback after a few seconds
the counter works with a kind of infrared LEDs, see photo. That's where the gears run, are the electrolytic capacitors around there bad?
Old 22nd Nov 2023, 5:53 pm   #3
Robsradio
Is there a Hall effect or optical sensor that is operated by one of the cassette spindles?
Robsradio is offline   Reply With Quote
Old 22nd Nov 2023, 6:15 pm   #4
Daltonagf
optical sensor, a gear with openings runs through it. the photo shows sensor.
Old 22nd Nov 2023, 10:43 pm   #5
ben
ben's Avatar
Look at the connections from the audio/control head to the main circuit board. Check for cracked solder joints or loose /dirty pins.
Regards,
Ben.
ben is offline   Reply With Quote
Old 23rd Nov 2023, 9:02 pm   #6
dj_fivos_sak
Unlike the early VHS machines which use an optical sensor or hall-effect sensor to advance the tape counter (if it's electronic), the more modern ones use the control track pulses to do that, so that you can have a real-time and more accurate counter readout. The machine is thinking the take-up spool is not turning and that's why it goes into emergency stop. I would suspect dry or cracked solder joints on the phototransistor/photodiode's leads.
dj_fivos_sak is offline   Reply With Quote
Old 24th Nov 2023, 8:55 am   #7
Daltonagf
just replaced c254 and c261, and it now works again. gr rob
ID:	288662   Click image for larger version
Reply
