Reply
Old 6th Nov 2023, 11:21 am   #1
220vBoy
Default Smiths Sectric Deluxe Self Starting Movement Directional Spring
Hello,
I recently acquired an ~85 year old Smiths wall clock with type 2 “deluxe” self starting movement. The synchronous motor starts right up and runs beautifully, but the spring mechanism for ensuring the self starting rotor rotates in one direction only, that being counter-clockwise (or anti-clockwise as you would say in UK) has detached. Is there anyone who could post a pic showing the detail of how this assembly is supposed to be fitted into place? I have attached a close up of the vicinity of the spring's placement and a pic of the three parts I found rattling around in the bakelite housing of the movement
ID:	287457   Click image for larger version
220vBoy is offline   Reply With Quote
Old 6th Nov 2023, 11:49 am   #2
Nickthedentist
Nickthedentist's Avatar
Default Re: Smiths Sectric Deluxe Self Starting Movement Directional Spring
Hi David and welcome,
Does this old thread answer your question, I wonder? "Catgut pegs" maybe?!
https://www.vintage-radio.net/forum/...ad.php?t=89102
Nick.
Nickthedentist is online now   Reply With Quote
Old 6th Nov 2023, 11:53 am   #3
220vBoy
Thumbs up Re: Smiths Sectric Deluxe Self Starting Movement Directional Spring
My gosh, that’s it! Thanks a million
Old 7th Nov 2023, 6:59 am   #4
220vBoy
Movement with spring installed, running as it should. Thanks again
Old 7th Nov 2023, 10:24 am   #5
220vBoy
Completed clock, ready to be installed
ID:	287484   Click image for larger version
ID:	287485   Click image for larger version
Old 7th Nov 2023, 10:31 am   #6
220vBoy
Another pic with different lighting to minimize the reflection in the mirrored copper face
Old 7th Nov 2023, 11:17 am   #7
paulsherwin
paulsherwin's Avatar
Nice clock.
If I were you I'd replace the power cord though - it looks original, which is great cosmetically but a bit risky.
paulsherwin is online now   Reply With Quote
Old 7th Nov 2023, 11:23 am   #8
220vBoy
Thank you. That cord is original but is from another Sectric clock, which is working but unused in my collection. I won’t be running the clock off of it.
I have a couple new old stock Wylex extra flush clock connectors and will be using one along with a new 22 gauge braided cloth pigtail and a 2 amp flex extender when I mount this clock on the wall
Old 7th Nov 2023, 12:56 pm   #9
Nickthedentist
Lovely!
I note it's a 240V, 50Hz model. Seeing as you're in the USA, how are you dealing with that?
N.
Old 7th Nov 2023, 1:09 pm   #10
220vBoy
Originally Posted by Nickthedentist View Post
Lovely!
N.
Thanks. I greatly appreciate you pointing out that thread, as it was the key to completing this clock. The spring serves a dual purpose: It governs the direction of the rotor, and it produces a soft tick-tick-tick sound similar to a wind up clock to indicate that the clock is running.
I have a frequency converter in the basement. It takes in American 240v 60Hz, converts it to dc, then inverts it to the 230-240v 50Hz the clock needs. Currently there are 4 wall clocks running off of it; this latest one will make 5 of them. I use 600v rated 18 gauge 2 core marine cable (similar to romex) behind the walls plus either MK or Wylex clock connectors or European 2 pin outlets to wire them up.
Pics of the converter and the clock in before restoration condition
ID:	287504   Click image for larger version
ID:	287505   Click image for larger version
Old 7th Nov 2023, 2:53 pm   #11
Nickthedentist
Thank you! I'm impressed.
Old 7th Nov 2023, 3:40 pm   #12
paulsherwin
We tend to forget that most American houses have a 120-0-120 supply, and use 240V to power things like cookers and air conditioners.
Reply
