Reply
Old 29th Oct 2023, 3:21 am   #21
winston_1
Default Re: Any electric iron experts out there?
I have a M.R. iron of my late mother’s, at least 60 years old. The bulb was a MES torch bulb size with green glass. When it failed I used a 2.5v 0.3 amp torch bulb which is just fine except I could not get a green one.
winston_1 is offline   Reply With Quote
Old 29th Oct 2023, 9:30 pm   #22
petertheorgan
petertheorgan's Avatar
do what I have done with indicators in the past , buy a bottle of green nail varnish and "paint" a normal torch bulb
petertheorgan is offline   Reply With Quote
Old 29th Oct 2023, 11:32 pm   #23
Graham G3ZVT
Graham G3ZVT's Avatar
A "Sharpie" permanent marker of your chosen colour works well too.
Graham.
G3ZVT
Graham G3ZVT is online now   Reply With Quote
Old 30th Oct 2023, 12:01 am   #24
kirstyd
the bulb is a Lilliput ES but the actual glass bulb was a small globe as apposed to the cylindrical type.
kirstyd is offline   Reply With Quote
Old 30th Oct 2023, 1:45 pm   #25
McMurdo
McMurdo's Avatar
Did you say you managed to read the voltage on the smashed one?
Ebay have E5 base bulbs, the ones aimed at penlights have a tiny lens at the end (lenticular glass) and are shorter than a standard LES
https://www.ebay.co.uk/itm/354220082...parms=ispr%3D1
Kevin
McMurdo is online now   Reply With Quote
Old 30th Oct 2023, 7:19 pm   #26
CambridgeWorks
CambridgeWorks's Avatar
OP, Post 13:
"One side of the bulb holder is connected to the live connection and the other to earth".
Although picture confirms that it is connected to blue, neutral, not live. This can't be right.
Would fail a PAT test, maybe trip an RCD and if mains were reversed, explode!
Rob
Apprehension creeping like a tube train up your spine - Cymbaline. Film More soundtrack - Pink Floyd
CambridgeWorks is offline   Reply With Quote
Old 30th Oct 2023, 11:16 pm   #27
kirstyd
yes you are right .the bulb is connected to neutral and earth [is this wrong?] .the shunt is also connected to the earth pin
Old 30th Oct 2023, 11:46 pm   #28
kirstyd
just had a closer look at the connections and its now clear that the earth connection and the one directly behind it are separate so one side of the bulb is on the neutral and both the shunt and the other bulb connection are on the connection behind the earth . Hope this makes sense.
Old 31st Oct 2023, 7:11 am   #29
CambridgeWorks
Just measure the voltage across the bulb holder feed points when the iron is heating up. Be careful with meter probes not to slip!
Rob
Old 3rd Nov 2023, 4:56 pm   #30
Brigham
As far as I remember, the live lead goes straight to the top end of the element, the bottom of the element goes to one pole of the thermostat, and the other pole goes to the neutral lead. The indicator lamp is across the contacts of the thermostat, and only lights when the iron is hot, and the contacts open.
Can't remember a shunt, but it's a long time ago.
Brigham is offline   Reply With Quote
Old 3rd Nov 2023, 8:22 pm   #31
CambridgeWorks
Different models, different configuration.
Rob
Reply
