Reply
Old 11th Aug 2023, 10:22 am   #1
paul farn
Default SMPS chopper transformer.
Can a chopper transformer be tested for shorted turns? Got a LOPT tester courtesy TV mag but would it work on above? Probably not.
P.
paul farn is offline   Reply With Quote
Old 11th Aug 2023, 10:27 am   #2
TonyDuell
Default Re: Don't know
I've used a ringing tester built from Television magazine to test chopper transformers. It seems to pick up shorted turns OK, as you might expect. After all, it just shows that the oscillations are heavily damped due to the energy absorbed in the shorted turn.
TonyDuell is offline   Reply With Quote
Old 11th Aug 2023, 12:40 pm   #3
toshiba tony
toshiba tony's Avatar
Might be related but I used to "ring" lopts. Just attach the two top connections to check line output transformers. If you got EHT on the primary you could assume the transformer was good, never let me down.
toshiba tony is offline   Reply With Quote
Old 12th Aug 2023, 10:44 am   #4
paul farn
Have you got a copy of this cct?It sounds like the right device for the job.I would think you also need a 'scope to view.Is that right?
P.
Old 12th Aug 2023, 11:57 am   #5
Graham G3ZVT
Graham G3ZVT's Avatar
Default Re: SMPS chopper transformer.
To get this shot, I think I simply had one probe on the Y input and the other on the Cal output and connected them across the primary winding of the Loptx I was testing.
Graham.
G3ZVT
Graham G3ZVT is online now   Reply With Quote
Old 17th Nov 2023, 11:06 am   #6
paul farn
Applied ringing test to device as described ie:cal-winding-i/p.Acceptable trace obtained similar to above.
Power diode shorting on sec which I should've checked earlier.Could've saved ages.Ah didnae ken.
Put it all back together & not a bad picture considering tube is 38,TX 100 series.Is this a record?
A few other components want replacing sometime.....
Old 17th Nov 2023, 11:57 am   #7
its ur aerial
its ur aerial's Avatar
That Diode was a common fault back in the day, was it D22, a BY298 memory fading.
Ken G6HZG.
Life is not Hollywood, life is Cricklewood.
its ur aerial is offline   Reply With Quote
Old 20th Nov 2023, 11:34 am   #8
paul farn
Ken G6HZG.
It was the other one actually.D15(byw74).
P.
Old 21st Nov 2023, 7:24 am   #9
its ur aerial
Paul, thanks for jogging the memory
Ken G6HZG.
Old 21st Nov 2023, 9:10 am   #10
Radio Wrangler
Radio Wrangler's Avatar
All transformers can be tested by a ringing technique, though sometimes you may need to add a capacitor to get a ring frequency you can use. Interpretation might be best by comparison with a known good one. For RF transformers you need a fast-edged pulse generator and a fast scope or a TDR.
Radio Wrangler is online now   Reply With Quote
Reply
