Old 4th Dec 2023, 9:11 pm   #1
dougietamson
dougietamson's Avatar
Default Rogers Type S324 Low Distortion AF sig gen
I've got one of these on the bench to get back to life, will be used in my local mens shed 'repair shop', we are low on test equipment.
1st thing is I have no idea how to get the case open, anyone come across one of these before.
Add from WW 1973 attached and some photos.
Doug
Name:	ROGERS TYPE S324.jpg
ID:	289228   Click image for larger version
ID:	289229   Click image for larger version
ID:	289230   Click image for larger version
ID:	289231   Click image for larger version
dougietamson is online now   Reply With Quote
Old 4th Dec 2023, 9:34 pm   #2
frsimen
Default Re: Rogers Type S324 Low Distortion AF sig gen
Does the case slide off if the feet or any screws underneath are removed?
frsimen is offline   Reply With Quote
Old 4th Dec 2023, 9:43 pm   #3
chriswood1900
Undo the screw on the front above the on off switch and the back of the case should slide off.
Chris Wood
BVWS Member
chriswood1900 is offline   Reply With Quote
Old 4th Dec 2023, 9:48 pm   #4
That looks like an adjustment hole for a screwdriver to me. The chassis definitely slides out from the front though, perhaps the big screw on the rear panel secures it?
Old 4th Dec 2023, 9:54 pm   #5
chriswood1900
No it’s not an adjustment hole, it is a long screw that goes through to the back of the case, it appears on several Rogers instruments I have worked on.
Chris Wood
BVWS Member
Old 4th Dec 2023, 10:13 pm   #6
dougietamson
Thanks for the info.
1st thing I did was to removed the 4 feet thinking that would be the key, no joy.
The large round screw at the back turns but feels like it's not doing anything.
I'lll try the front screw tomorrow.
There's some loose parts inside, hope not too terminal.
Old 4th Dec 2023, 11:31 pm   #7
Nickthedentist
Nickthedentist's Avatar
I was thinking the same as you, Graham, but the legend around the hexagonal chromed escutcheon says "unlock", with an arrow pointing anticlockwise. So I think Chris is right
Nickthedentist is online now   Reply With Quote
Old 4th Dec 2023, 11:48 pm   #8
Wellertcp
Suggest gently prising off the metal caps on each end of the handle. There may be screws hidden underneath the caps.
This is the arrangement on the Sugden oscillator, this unit may be similar. The same arrangement on Farnell power supplies, iirc.
Wellertcp is offline   Reply With Quote
Old 5th Dec 2023, 8:13 am   #9
dougietamson
That was my final though before asking for help, so had a 'go' at them, they didn't feel like co-operating so gave up.
Old 5th Dec 2023, 9:21 am   #10
I stand corrected.
I don't see where it says "unlock" though.
Old 5th Dec 2023, 9:43 am   #11
Nickthedentist
Ah, I couldn't either, but I did a Google image search for a Rogers S324 which led to an online auction with excellent close-up pictures:
https://www.ebay.co.uk/itm/276145556755
Old 5th Dec 2023, 10:11 am   #12
dougietamson
Thanks to the help here I've got it open
Chris was spot on with the 'unlock' screw.
The rattle was from the mains PSU not being attached to the back of the case and its 2 screws rattling around, I've screwed the PSU back in place.
I've added more photos.
Next up is to check the PSU for any surprises.
Doug
ID:	289255   Click image for larger version
ID:	289256   Click image for larger version
ID:	289257   Click image for larger version
Old 5th Dec 2023, 10:38 am   #13
If it's going into general usage in a workshop, a set of test leads with a good high voltage blocking capacitor along their way might be a wise next job. No telling where someone will go probing with it!
Old 5th Dec 2023, 11:19 am   #14
dougietamson
Good idea, the 'repair shop' has been running for about 2 years, most of the items are garden tools, lamps, coffee tables etc but the odd radio/audio item does appear.
I was asked to look at a 1962 Civic tape recorder that someone had tried to fix, I had to bring it to my 'lab' as we only had a cheap multimeter and a soldering iron at the shed workshop.
We've since acquired an old Hameg CRO, bench power supply and a proper meter and I built a lightbulb limiter.
These items are 'hidden' in a cupboard.
Old 5th Dec 2023, 11:55 am   #15
dougietamson
The PSU looks very clean, filter caps are in good condition, 3 transistors and, I assume, a trim pot to adjust the voltage.
PSU states 18vdc output, I measured 17.8vdc while on the bulb limiter with no load, close enough.
I connected the PSU to the unit and powered on, no smoke, then adjusted the trim pot to get 18vdc under load, clean sine wave on the scope.
Doug
ID:	289264   Click image for larger version
ID:	289265   Click image for larger version
Old 6th Dec 2023, 5:55 pm   #16
DMarchesi
i nearly bought that on ebay myself, good luck with the restoration
DMarchesi is offline   Reply With Quote
